IMHO - there's no plus when using OEM system... its full of bloatware, slow and not updated.
2nd, backtracker was made FOR USB RECOVERY (
SOURCE)
"For some Notebook don’t have CD-ROM drive and the architecture of the Windows is much bigger than before.
One piece of DVD is not able to back up the whole image of the Operation System .ASUS releases a new software Backtracker to back up the Operation System image to a USB drive"
3rd, try to toggle the "CSM" option in bios... you might "sit" on the wrong config, thus not being able to boot from usb/dvd.
4th, you might have bad usb / wrong partitioned... try to format your USB.
5th, we're not telepathic... if you want help, you need to provide more details, the more technical the better.
Asus G751JTSamsung EVO 850 120GB + 1TB HDD 7200RPM
Cleaned installed Win 10 HOME
My Guides:
- [POST=538713]ROG LAPTOPS: COMPLETE DRIVER LIST ![/POST]
- [POST=538713]How to install windows 8/8.1/10 on any UEFI supported laptop the PROPER way[/POST]
- [POST=538711]HOW TO (EASILY!) UPGRADE FROM WIN7 SP1/8.1 WITHOUT GOING THROUGH THE UPGRADE PROCESS ITSELF ![/POST]
- [POST=605307]HOW TO REMAP FN+KEY AND SPECIAL BUTTONS: "STEAM", "ROG" & "SHADOWPLAY"[/POST]
- [POST=539663]Win 10 x64: SETUP USB @SUPERSPEED, NO HANG-UPS! | ACCELERATES USB 3.0/2.0 TRANSFER RATE SPEED TWICE![/POST]
