Hello Guys,
I made the last month many times around my Pc and test many difference Settings in the Bios, but nothing is running.
The first thing ist, xmp Profil ist not running, with the newest Bios Version (5430), i dont try it with older Versions.
with xmp starts the Windows not, it leaves in black Screen.
so i try the manual 3600mhz Setting but it works not...
I know that i must Change the Settings optimal , singel but i dont know what....
here gives many peopels with the same Problem but i dont find the result ...
my Setup:
i7 8700k
Asus Strix z370-e
32GB Corsair Vengeance RGB DDR4-3600 DIMM CL18 Quad Kit
the Maximum Speed of ram what i use, without Performance Problems is 2600mhz.
when i start the autotuning, it works with 2133 mhz.
i think it is space to the top.
when everywhere nows whats the Problem, pls help me or give me a link where i found the exactly Settings of the ram.
my Goal is , let the ram works with 3600mhz, thanks before
