OLED Dead
Eric_Lajoie
The OLED display (LiveDash) never worked on my board and the AURA lighting never remembers its setting and needs to be reset after every reboot.
Any ideas? I have the latest AURA firmware and running the 804 UEFI.
pasty2k2
LiveDash is a separate firmware to AURA I think, have you tried flashing with an older firmware for it? I think its done from within Windows.
I haven't peeked under the IO shield myself yet but it must connect to the motherboard somehow, perhaps check the physical connection is OK/look for any burned out components or bridged solder points on the OLED's board, if it's easily accessible.
I haven't used AURA yet so can't help there apart from basic troubleshooting - is Windows a fresh install for this motherboard - what version of Windows are you running - is it up to date (creators update)? Try a fresh install if you can, download it direct from Microsoft and create a fresh USB installer, if you haven't already, I've found upgrading windows to the Creators Update version leaves it in a bit of a state, but fresh installs are fine.
Took a closer look and it is displaying but the backlight for the display is dead.
jiMMyoNewAy
If it has never worked then it has to be RMAed. Probably you got a bad display from the start. Did it ever lit up?
