ASUS Radeon RX 6700 XT graphics cards are ready to rip with ROG Strix, TUF Gaming, and Dual
The AMD Radeon™ RX 6900 XT and Radeon RX 6800 series graphics cards have infatuated high-end gaming enthusiasts since their launch, and ASUS has unleashed their power with several custom designs that deliver exceptional performance, acoustics and overclocking potential. Now, we’re bringing those same characteristics to mainstream gamers with custom Radeon™ RX 6700 XT graphics cards. Whether you want the uncompromising performance and cooling capabilities of ROG Strix, the durable and dependable power of TUF Gaming, or the compatibility and flexibility of our Dual cooler, there’s an ASUS Radeon™ RX 6700 XT graphics card that’s tailor-made for your PC.
The ROG Strix Radeon™ RX 6700 XT brims with beastly style and performance
The ROG Strix Radeon™ RX 6700 XT graphics card boasts an extroverted style that wraps up all of our latest innovations for air-cooled graphics cards. We start with a massive triple-slot heatsink that uses a dense array of fins run through with seven heat pipes for high heat dissipation potential. Heatsink and GPU meet using a baseplate finished with our MaxContact process for increased surface area and better thermal transfer from the GPU.
Three fans using our latest Axial-tech design push plenty of air through the heatsink at low noise levels for a chilly and quiet GPU. We carefully considered the role of each fan in the overall cooling design, refining their barrier rings and blade counts for optimal air dispersion through every part of the heatsink. A short custom PCB creates extra room for hot air to pass directly into the case’s airflow path through a cutout in the backplate, improving overall system temperatures. A pair of our exclusive FanConnect II headers allow gamers to tie case fan speeds directly to GPU temperatures for a rush of cooling airflow when the system needs it most. Finally, a zero-dB mode at idle and under light loads helps keep the system as quiet as possible.
Distinctive style comes standard on the ROG Strix Radeon™ RX 6700 XT graphics card. A black-and-gray primary color palette enhanced with metallic accents broadcasts your ROG allegiance to the world while integrating seamlessly with elaborate case lighting schemes. The ROG Strix card also features a bold full-length addressable RGB LED strip on its left edge that’s compatible with Aura Sync for a striking light show that’s easy to coordinate with compatible peripherals.
As a finishing touch, the full-length metal backplate doesn’t just look good. In tandem with a large stiffening frame, it minimizes PCB flex when the graphics card is installed in your system.
The TUF Gaming Radeon™ RX 6700 XT impresses with quiet competence
The TUF Gaming Radeon™ RX 6700 XT graphics card exudes quiet competence with a new industrial design. Its triple-slot heatsink comes sandwiched between a monochrome, brushed-aluminum shroud and a full-coverage backplate, both of which are imprinted with subtle TUF Gaming graphics to clue close observers in to your preference for purposeful performance. An Aura RGB-backlit TUF Gaming logo lets users put a finishing touch of color on the system, or it can be switched off entirely for a stealthy rig.
The TUF Gaming Radeon™ RX 6700 XT’s style may be stealthy, but its clock speeds, operating temperatures, and low noise levels make a big impression. Three counter-rotating fans built with our latest Axial-tech design move more air through the massive 2.9-slot heatsink at a given RPM for better performance without increasing noise output.
Differing blade counts between the central and outer fans optimize airflow for each zone of the heatsink to keep every component’s temperature where it needs to be. A large cut-out in the backplate ahead of the short custom PCB allows more hot air to enter the case’s natural airflow path for even better cooling performance. Finally, with a zero-dB fan mode at idle, the TUF Gaming Radeon RX 6700 XT is as easy on the ears as it is on the eyes.
This card is built to take whatever you can throw at it during lengthy gaming sessions. Auto-Extreme assembly technology, used across our lineup, precisely places and solders components without human intervention to boost reliability and build quality. A 144-hour testing regime and extra-sturdy capacitors ensure out-of-the-box reliability and a long service life, and a strong reinforcement frame minimizes PCB flex when the card is installed in your system.
The ASUS Dual Radeon™ RX 6700 XT puts big performance in a smaller package
The ASUS Dual Radeon™ RX 6700 XT graphics card is built to go where larger cards can’t. Our larger Radeon™ RX 6700 XT graphics cards are designed for systems where card length isn’t a limitation, but we know that many builders prefer microATX or Mini-ITX cases. The Dual Radeon™ RX 6700 XT graphics is just the ticket for those who are planning more compact PCs.
The Dual Radeon™ RX 6700 XT’s cooling power starts with a pair of fans built with our proven Axial-tech design. Their focused airflow moves through a 2.7-slot heatsink enveloped by a clean black-and-white shroud with a subtle LED accent for a classy, eye-catching style. The fans can stop at idle to keep your system’s noise signature as unobtrusive as possible during light loads.
A full-coverage aluminum backplate embossed with subtle graphics and a polished stainless steel mounting bracket keep this card looking good from any angle, while our Auto-Extreme assembly process and 144-hour validation cycle ensure it will reliably keep the pixels flowing.
For more information regarding the pricing and availability of ROG Strix, TUF Gaming, and ASUS Dual Radeon™ RX 6700 XT graphics cards in your region, please contact your local ASUS representative.
Autore
Post popolari
Come overclockare il sistema utilizzando AI Overclocking
How to maximize your ROG laptop's performance with the MUX Switch
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
Celebrating one year of the ROG Ally (and its amazing community)
Baldur’s Gate 3 on the ROG Ally: performance guide & best settings
Ultimi Articoli
ROG bridges the worlds of PC gaming and athletics with the ROG x Spalding Basketball
ROG's engineering excellence and Spalding's athletic expertise make for one unforgettable basketball.
WiFi 6E opens a fast lane for higher-speed, lower-latency wireless performance
Here's how the latest WiFi tech relieves congestion on crowded networks.
We've created three series of Radeon RX 6700 XT graphics cards to ensure there's one that's right for every builder.
The ROG Rapture GT-AXE11000 gaming router opens the Wi-Fi 6E frontier
6GHz Wi-Fi spectrum is coming with Wi-Fi 6E, and the ROG Rapture GT-AXE11000 is the first router that can take advantage of this new frontier.
Vetrina prodotti: ROG MATRIX RTX 2080 TI
La nuova ROG Matrix ridefinisce il concetto di VGA per enthusiast grazie a Infinity Loop, l’esclusivo sistema di raffreddamento a liquido a loop chiuso integrato direttamente nello chassis della scheda
Vetrina Prodotti: ROG Strix Helios
Dopo aver illuminato la maggior parte dell'ecosistema del tuo PC, il nuovo passo per ROG non poteva che essere un case dotato di tutte ottimizzazioni per il mondo Aura. Arriva finalmente ROG Strix Helios!
