Spider-Man Remastered on the ROG Ally performance guide & best settings
Image source: Gamesplanet
Marvel’s Spider-Man: Remastered is one of the best single-player story games of the past decade, and now you can take it anywhere with you on the ROG Ally. If you want the best balance of graphical beauty and stable framerates, here are our recommendations for the best settings.
This is part of our ultimate guide to the ROG Ally series of articles. For more great games, check out our recommendations here.
What framerate to expect in Spider-Man Remastered on the ROG Ally and ROG Ally X
The hustle and bustle of Manhattan is rather demanding, even on higher-end PC hardware. Thanks to the Ryzen Z1 Extreme and Armoury Crate’s Turbo Mode, though, the ROG Ally is able to run this title with good performance, averaging just under 60 frames per second in most cutscenes and missions, with occasional dips into 40s in certain parts of the open world. Performance is also served by AMD’s FSR, which serves the double purpose of raising framerates while reducing aliasing in the image, producing a result that I find looks better than native 1080p. And if you turn on Frame Generation, you can smooth things out even more, offering a truly high-framerate experience of 80 FPS or more. Since the Ally is equipped with FreeSync Premium display, motion looks smooth the whole time, offering a very enjoyable trip through Marvel’s New York.
Spider-Man Remastered optimized graphics settings for the ROG Ally and ROG Ally X
You could just pick from one of the game's built in graphics presets, but for the best possible image quality and gameplay, we did some tweaking to find the best looking settings that keep the game at a smooth framerate. You can leave the framerate uncapped for best possible performance, or turn on the Ally’s FPS Limiter to your desired framerate for a more consistent experience. Here’s what we recommend.
- Resolution: 1920x1080, the native resolution of the ROG Ally display.
- Frame Generation: On. Turning this one will get you even smoother framerates, and Spider-Man lends itself to this type of motion smoothing, so we recommend turning it on. However, you can Turn it off if you prefer.
- AMD FSR 3: On, Quality. This renders the game at a lower resolution to ensure a solid framerate, then uses temporal upscaling to bring the resolution back to 1080p. It isn’t absolutely crucial for a good experience in Spider-Man, but this is one of those games where FSR looks and performs better than native thanks to the way it reduces jagged edges and shimmering.
- Texture Quality: High. This setting is mostly VRAM-dependent, so we can set it to High without much performance penalty as long as you increase the Ally’s VRAM allocation. (On the Ally X, you can just set it to High without worrying about the VRAM.)
- Texture Filtering: 8x Anisotropic. This determines the quality of textures seen at a distance. For this screen size and resolution, 8x provides good performance and looks almost the same as 16x.
- Shadow Quality: Low. The difference between Low and High is quite subtle in Spider-Man Remastered, so this is a good way to save on a bit of performance without losing much visual quality.
- Ambient Occlusion: SSAO. This setting affects the little shadows that give the 3D world depth, and is a must-have for a realistic looking New York City. SSAO is the best looking option here.
- Screen Space Reflections: On. In a game with so many mirror-like windows, you definitely want this turned on for nice-looking reflections.
- Ray-Traced Reflections: Off. Screen Space Reflections should be good enough on the Ally’s handheld screen, while offering better performance than ray tracing.
- Level of Detail: Very Low. This adds more detail to faraway objects in the city, but you’re unlikely to notice in most cases on a screen like the Ally’s. Get some performance back by turning this down.
- Traffic Density: Very Low. The number of cars on the road can hammer the CPU pretty hard, so Very Low offers a welcome boost in performance while still looking great.
- Crowd Density: Very Low. Crowd Density is similar to Traffic Density, so the lowest setting offers the best performance.
- Hair Quality: Low. On the Ally’s screen, you likely won’t notice a huge difference between the different hair settings, and setting it to Low offers a major performance boost in many cutscenes.
- Weather Particle Quality: Medium. This offers a good balance between performance and nice-looking weather effects, like clouds.
- Depth of Field: Low. Turning this down gives a big performance advantage and likely isn’t too noticeable in cutscenes.
- Camera Effects: Set to Taste. Effects like Bloom, Lens Flair, and Motion Blur are mostly stylistic options that some people will like, and others won’t. Feel free to experiment with these to suit your visual and performance preferences.
As with any optimized settings, feel free to adjust these to your taste. We’ve done lots of testing to find what we consider the best balance of graphical quality and performance, but your preferences may vary. Customizability is one of the best parts of Windows gaming, so use our settings as a starting point and get to tweaking!
Auteur
Popular Post
The 2025 ROG NUC: Your next-gen mini PC for tomorrow's AAA games
15 tips & shortcuts to set up and optimize your ROG Ally or ROG Xbox Ally
The 2025 ROG XG Mobile Leads New Era of eGPUs with Thunderbolt 5
Laatste Artikelen
The best 2D platformers for the ROG Xbox Ally
If you want to play the latest and greatest 2D platformers, the ROG Xbox Ally is the handheld for you.
The best 3D platformers for the ROG Xbox Ally
Whether you like your 3D platformers speedy, precision-oriented, or relaxed, there are plenty of titles for you to enjoy on your ROG Xbox Ally or ROG Ally handheld.
ROG Ally vs ROG Xbox Ally and ROG Xbox Ally X: All the improvements in the newest ROG gaming handhelds
With the ROG Xbox Ally, we took everything you loved about the original ROG Ally and made it better.
How to play games offline with the ROG Ally and ROG Xbox Ally
The ROG Ally is designed to play all your games, wherever you go — even if you don’t have an internet connection.
The ROG Xbox Ally is coming — here's everything you need to know
The cutting-edge ROG Xbox Ally packs next-gen power and portability so you can game on the go better than ever before.
Introducing the ROG Xbox Ally and Ally X: ROG and Xbox team up to deliver the best in handheld gaming
We are incredibly proud to announce the ROG Xbox Ally series of handhelds, which take the ROG Ally lineup to all new heights in performance, comfort, and user experience.
