How to increase FPS on the ROG Ally with FSR 3 and AFMF 2
Despite its compact size, the ROG Ally and ROG Ally X are packed with power, thanks to the AMD Ryzen Z1 series APU inside. If you want an even smoother experience in your favorite games, the Ally also supports the latest AMD FidelityFX Super Resolution 3 (FSR 3) and AMD Fluid Motion Frames (AFMF) features, allowing for intelligent frame generation that adds even more smoothness. Here’s how to boost your FPS with these exciting new technologies.
This is part of our ultimate guide to the ROG Ally series of articles.
FSR 3 frame generation increases FPS in supported games
FidelityFX Super Resolution, or FSR, is a suite of performance-boosting technologies built into modern games. The first version of FSR was an upscaler that rendered your game at a lower resolution, then scaled it up intelligently to boost performance while retaining image quality. FSR 2 improved on this technology by incorporating temporal information into the algorithm for even higher image quality — you can read more about AMD’s different upscaling features in this guide.
FSR 3 incorporated an entirely new technology to games known as frame generation. By analyzing that same temporal data, frame generation can use information from the current frame to generate new frames that slot in between traditionally rendered ones. The result is gameplay that appears much smoother, even at high graphics settings. And because FSR is integrated into each game by the developer, UI elements and text will be rendered normally, resulting in a high-quality image with fewer artifacts than, say, using the motion interpolation setting on modern TVs. Latency will also be lower than typical interpolation methods, thanks to optimizations from AMD in the frame generation pipeline.
AMD has since improved FSR even further with the release of FSR 3.1, which enhances image quality during upscaling. To use these technologies, however, your game needs to support FSR upscaling and frame generation. You can see a list of games that support FSR 3 and FSR 3.1 here.
To enable FSR 3 frame generation, open your game’s Graphics or Display settings, look for the AMD FidelityFX Super Resolution 3 setting and turn Frame Generation on. AMD also recommends turning on a frame limiter or VSync to keep your framerate within the display’s refresh range. In addition, the higher your starting framerate, the smoother your experience will be and the lower latency you’ll experience. So AMD also recommends adjusting your in-game settings to target 60 FPS if possible before applying frame generation. So try to adjust your in-game graphics settings to target a base framerate of at least 45 to 50 FPS (or higher) before applying frame generation.
AFMF 2 adds smoothness to games that don’t support FSR 3
While FSR 3 frame generation is getting added to new games all the time, certain titles may not support this technology, or may have been released before FSR hit the scene. In those cases, AMD has a driver-level feature called AMD Fluid Motion Frames, or AFMF, that can apply frame generation to a much larger variety of games.
While AFMF is based on similar technology to FSR 3, it doesn’t have as much information to work with — since it isn’t integrated into the game, it doesn’t have motion vectors to incorporate, and UI elements will be part of the interpolated frames. As a result, FSR 3 is preferred if your game supports it. If the game you’re playing doesn’t support FSR 3, then you can enable AFMF.
The latest version of this frame generation technology comes with some notable improvements. AFMF 2 offers lower latency than its predecessor, and it supports Borderless Fullscreen mode as well as Vulkan and OpenGL — leading to increased compatibility with the games you’re playing. In addition, AFMF 2’s Performance Mode should perform even better on integrated graphics like the AMD Ryzen Z1 and Z1 Extreme in the ROG Ally and Ally X, and its Search Mode optimizes the frame generation for different resolutions. You can adjust both of these settings in AMD Software Adrenalin Edition if you want to experiment, but the Auto setting (which defaults to Performance and Standard, respectively) should already give the best results on the Ally and Ally X, so there’s no need to tweak them. The latest AFMF 2.1 revision improves image quality as well, with reduced ghosting, better fine detail, and improved handling of overlay text. Just make sure you head to Armoury Crate’s Update Center to download the latest graphics drivers.
Finally, there are a few things you’ll want to keep in mind when using AFMF. Like FSR 3 frame generation, you’ll have the best experience if you adjust your in-game graphics settings to hit around 45+ FPS before applying AFMF — the more frames you start with, the better AFMF will work. You can see our recommended ROG Ally settings for popular games here, which usually target 45-60 FPS.
Next, you’ll need to ensure your game is running in Full Screen or Borderless Full Screen mode, as AFMF does not work in windowed mode. In addition, you’ll also want your display set to 120Hz in-game with VSync turned off. Note that this may produce screen tearing if your game exceeds 120 FPS, so you may want to limit your base framerate to something below this — with most games, a 60 FPS cap will ensure consistent frame pacing, but what you choose is up to you. Also, while AFMF works in thousands of games, there may be some games it does not work with — like those with built-in framerate caps locked to a certain refresh rate.
Finally, to enable AFMF, just head to Settings > Performance > GPU Settings in Armoury Crate SE and turn AMD Fluid Motion Frames (AFMF) on. You can also add it to the Command Center from Armoury Crate’s settings for quick access at any time, or access AFMF from the AMD Software.
Do it all in one click with HYPR-RX
FSR 3 and AFMF are only a few of AMD’s game-optimizing technologies. AMD has also made it easier than ever to get the most out of your games with a new feature called AMD HYPR-RX. With one click, AMD HYPR-RX will turn on a number of performance-boosting settings so you can get straight back to gaming. Just turn HYPR-RX on in the AMD Adrenalin software under Gaming > Graphics.
For example, if the game in question is in AMD’s HYPR-Tuned games list, enabling HYPR-RX will automatically set Radeon Super Resolution (RSR) or FSR to the Quality preset, alongside AMD Radeon Anti-Lag and AMD Radeon Boost. HYPR-RX will instead enable AFMF to ensure you get the smoothest experience possible. HYPR-RX does not currently enable FSR 3 frame generation, so if your game supports the feature, you'll want to turn that on manually in addition to HYPR-RX (and disable AFMF if it's already turned on).
With these tools in tow, you can achieve serious performance on the ROG Ally and play all your games anywhere. For more tips on optimizing your games, check out the rest of our ROG Ally guides – including how to boost gaming performance on the ROG Ally and even what settings to tweak in specific games for the best experience.
Popular Post
ASUS Republic of Gamers Announces Availability of Strix OLED XG32U Series
Pre-Orders are Open: Secure your ROG x Hatsune Miku Edition PC
ASUS Republic of Gamers Unveils ROG x Hatsune Miku Edition Collection
Armoury Crate Operating Modes Explained: Silent Vs Performance Vs Turbo Vs Windows
The ROG Xbox Ally is coming — here's everything you need to know
Level up your calls: ROG gear and tips to dominate Discord and Zoom alike
ROG headsets, laptops, and software give you the technology you need to effortlessly dominate virtual work meetings and gaming voice chats.
ROG Xbox Ally vs Gaming Laptop: which portable gaming device is right for you?
Both the ROG Xbox Ally and ROG gaming laptops have a lot to offer gamers, depending on what they're looking for.
Which ROG Xbox Ally to give the gamer in your life this holiday
The powerful, portable ROG Xbox Ally is the perfect gift for any gamer who wants to take their favorite games everywhere they go.
The best accessories to supercharge your ROG Xbox Ally
Here’s the must-have gear that’ll catapult your ROG Xbox Ally gaming to the next level.
How to extend the battery life of your ROG Ally or ROG Xbox Ally
The ROG Ally’s compact, lightweight form factor allows you to play all your favorite modern games anywhere you go. Here are a few tips to extend your game time as long as possible.
The ROG Ally is a true Full HD handheld ready to make your games look better than ever. Here's how to maximize its performance.
