How to keep your ROG SLASH 4.0 bags in peak condition
Our ROG SLASH 4.0 Bag series is here, giving you the latest and greatest in fashion built to transport your gaming gear. All three SLASH 4.0 series bags are made of polyester and durable, stylish PU leather, giving you strong, snazzy options for all your needs. But even though the latter material can hold up well all on its own, it’s still a good idea to manually maintain your gear’s PU leather for maximum luster and longevity. Here are a few tips to help keep your ROG SLASH 4.0 bags in top condition.
How to safely clean PU leather with regular upkeep
You’ll want to give your PU leather gear a periodic cleaning to prevent dust and dirt from building up. First, use a soft brush or cloth to remove loose gunk from the surface of your bag. Then, gently wipe the surface with a clean, lightly water-dampened cloth. Don’t wet the cloth too much; drowning or soaking your PU leather can damage it.
Be sure to avoid harsh chemicals when cleaning. Bleach, acetone, and ammonia-based cleaners can damage PU leather products, fading the material or worse. So, stick with water for the best results. If you need a bit of extra strength, opt for mild soaps or specialized leather cleaners.
The best way to clean stains on PU leather
Address stains right away; don’t let them settle. Blot the affected area with a clean cloth or paper towel to mop up whatever’s mucking up your merch. Don’t rub the stain. If you rub, you risk spreading the stain or pushing it deeper into the PU leather.
After blotting, use a damp cloth to gently wipe down the affected area until the stain is gone. It’s that easy. Let your bag’s surface dry, and it’ll be good as new, back to how it was before you dropped your Mountain Dew.
Avoid excessive heat exposure and sharp objects
Prolonged exposure to sunlight and intense heat can cause PU leather to fade, crack, and warp. So don't leave your PU leather gear sitting in the sunlight for long stretches of time. Also make sure your SLASH 4.0 gear isn’t close to heat sources such as radiators or heaters for excessive durations.
Be sure to keep your ROG bag away from sharp objects. PU leather isn't immune to scratching or tearing. Pointy objects brushing against your bag can puncture and scuff your ROG SLASH 4.0 gear, so try not to let your stylish bag smack against stuff you wouldn’t want to bump into yourself.
Enjoy your ROG SLASH 4.0 gear for years to come
By following these steps, you'll be taking good care of your ROG SLASH 4.0 gear, ensuring it looks its best for years to come. Treat your bag well and it’ll carry your ROG tech like a champ.
For more information about pricing and availability of the ROG SLASH Bag series in your region, contact your local ASUS representative.
Popular Post
Armoury Crate Operating Modes Explained: Silent Vs Performance Vs Turbo Vs Windows
How To Tweak Your ROG Laptop’s Performance With Armoury Crate’s Manual Mode
The 2025 ROG XG Mobile Leads New Era of eGPUs with Thunderbolt 5
What CPU does your PC have? Here’s how to check
The best settings for your ROG laptop: how to get the best PC gaming experience
Here are the most important Armoury Crate settings to check before you dive into your favorite games on your ROG gaming laptop.
Best Laptop for Students and Gaming in 2025: ROG’s Picks for College
No matter which university or major you choose this fall, ROG has the right gaming machine for your campus life.
How to choose a gaming laptop: The ultimate 2025 buying guide
Learn how to choose a gaming laptop with our complete guide, ensuring you find the perfect match for your gaming needs and preferences.
Can I overclock my GPU with Armoury Crate?
If you have an ROG machine — whether it’s a gaming desktop or a gaming laptop — you can control most of its functions from the bundled Armoury Crate software. On laptops, this includes tuning your GPU performance and overclocking your graphics chip. On desktops, you'll need GPU Tweak III as well.
Do I need Armoury Crate on my PC?
If you just bought an ROG desktop PC or gaming laptop, you may be wondering what the preinstalled Armoury Crate software does. Here are its banner features.
How to fix a device that's not showing up in Armoury Crate
If Armoury Crate isn’t automatically detecting your new device, don't worry — you probably just need to download a quick update.
