What’s Inside My ASUS Graphics Card?
Ever wondered what’s inside your ASUS graphics card? Well we decided to take apart and investigate the previously detailed ASUS GeForce GTX 550 Ti DirectCU and GeForce GTX 560 Ti DirectCU II graphics cards to find out.
It's oh so naked! ASUS GeForce GTX 550 Ti sans its DirectCU cooler.
Breaking them apart!
Four screws on the back whips off the DirectCU cooler. It’s not actually that heavy despite using two or three, fat copper heatpipes, as the aluminium fins that dissipate the heat make up much of its size. The heatpipes directly make contact with the GPU core too meaning the heat is transferred more efficiently. As you can see, the DirectCU II cooler is notably larger with three heatpipes on the GeForce GTX 560 Ti, as it has to cool a larger GPU core.
While both versions are up to 20% cooler than the reference design, DirectCU II with its dual-fan setup pushes 600% more air than the standard, single fan, meaning it can not only run quieter at normal clock speeds, but there’s more overhead for overclocking too.
  The actual PCBs are upgraded as well – whereas the GeForce GTX 550 Ti uses 4+1 phase VRM the GeForce GTX 560 Ti is fitted with a 6+1 phase VRM. Both use the latest Super Alloy Power hardware – as signified by the ‘SAP’ logos on the electrical chokes. These are both 35oC cooler while also giving 15% more power than the reference hardware, adding to that running cooler/greater overclocking overhead vibe. You really need both parts to get the absolute most of of your new GPU.
On each 6-pin power connector and 16x PCI-Express connector there’s a little white square with gold edges: this is the fuse protection that prevents serious damage to your graphics card ?from rouge power supplies or spikes from the wall socket (in some countries the local power is unfortunately not that reliable). The other addition is the GPU Guard – a metal bar that screwed into the edge of the PCB. This not only adds a touch of metal flair down one side, but it’s main job is to strengthen the PCB so it resists bending and flexing. Bending can sometimes break tiny solder joints during installation, killing the card, so obviously this is best avoided!
  If you’re already running an ASUS DirectCU(II) card let us know your experiences, or if you have any questions please drop them in the comments below! This article was originally written by Nick Holland on Techinstyle.tv.
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - How to upgrade the SSD and reinstall Windows on your ROG Ally, ROG Xbox Ally, or ROG Xbox Ally X
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
