Unboxing The Orion PRO Gaming Headset
So you're thinking about an Orion PRO, eh? Good for you, son! But just to be sure before you hit the order button or jump in the car, you want to know what you get in the box, right? Well put your hand on the mouse and use your index finger to scroll the wheel down.
Either you've ripped open the cardboard box that says "Amazon" on it or you've pulled it off the shelf of your local store. Either way it looks like this:
Aaand the back:
Flip the lid and the first thing you'll see is the manual and warranty. Boring bits I'm sure, but keep it safe just in case. If you read it secretly then no one will know and we won't mind.
Yoink! OK all looks good: ROG cable tidy on the left, USB Spitfire audio processor in the middle and the Orion headset are all neatly tucked in.
We've seen the Spitfire up close before, but here's how to use the cable tidy. Note it only comes with the PRO though. There's 2.5m of cable connected to the Orion, which is enough to reach from one side of the room to the other, but you'll be glad of the easy cable tidy to keep it out of chair wheels.
The microphone is hidden into the ear-cup itself so you'll never lose it, and when out it's adjustable to whatever angle you prefer:
[gallery include="" size="large" link="file" template="file-gallery"]
Got any questions still? Drop them in our forums!
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - ASUS GPU Tweak III: The ultimate tool for advanced GPU tuning
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
