The Need for Speed: Maxxing Your Connection Speed
Playing games successfully online relies on snappy speed. If you've noticed your gaming's gotten a bit sluggish of late, wait a minute before dropping the big bucks on a PC upgrade. The speed issues might not be your machine, but the way it connects to the internet. These simple tweaks can help minimize your ping and maximize your successes!
1: Run a speed test. It always helps to know where you're starting from. To check out what your connection's actually like, run Speedtest. This handy (free!) service will tell you your ping, download speed, and upload speed, all of which can impact your online gaming. The most important factor is ping, which is the time it takes for data to get to and from the game server — you want that number to be as low as possible. A ping of 30ms on a 15Mbps connection is a good set of numbers to aim for. Your download speed, on the other hand, should be as high as possible, but anything above 5Mbps should be acceptable for most games.
2: Get rid of interference. If your home network uses wifi, there are a number of easy things you can do to improve speed to your connection. Here's a list of 10 handy tips to boost your wifi — try moving your router, changing wireless channels, and getting rid of interference. You can even increase your wifi range using a beer can, if that's the way you roll.
3: Clean up your act. If your network speed is okay, but your games still aren't snappy enough, give your machine a clean, inside and out. Clean up your programs and even perform a fresh Windows install to remove memory-resident apps. You can have protection against incoming malware and viruses before it reaches your home network using AiProtection, this way your PC can run faster from using less resources.
Of course it won't hurt to literally get out the vacuum! Open up your PC case and take a good look inside. Check that all of the fans are running smoothly and that the filters are free of dust. All that hair, dirt and grime that builds up inside the machine over time (particularly if your PC sits on the floor and your Persian cat Muffy loves to sleep on it) will actually affect its performance, by preventing the PC from cooling properly. These tips might help, but don't forget to switch the power off before you get in amongst the parts with a can of compressed air.
4: Get a new ISP. After all that, you simply might not be able to get decent speeds on your current connection. This doesn't mean that your lucrative eSports career is over before it starts, however. Do your research and look into what ISPs operate in your area. If you're using outdated technology (you're not still on dialup, are you?), there's a good chance you can upgrade to a better connection. If you're using mobile internet, switching from 3G to 4G will make a massive difference, and changing wireless carriers can also help. If all else fails, it is possible you may need to move house if you are serious about online gaming... maybe.
5: Get a new router. Unless you live alone or can wait until everyone has gone to bed to use the precious bandwidth your connection provides, you're probably not getting the ping with that N-series router from 2010. It's time to upgrade to a dual-band or tri-band wireless router. The ASUS RT-AC88U (dual-band) or the ASUS RT-AC5300 (tri-band) is the answer to your prayers, pushing your range farther and your ping lower than ever. They also work as wired LAN routers and has WTFast, the Gamers Private Network (think VPN, but for gamers only) built in.
Popular Posts
Level up your Xbox, PlayStation, and Nintendo Switch 2 with these ROG accessories
ROG has headsets, controllers, and other gadgets that’ll amp up your console experience, too.
How ROG reinvents the PC gaming platform
Here's why millions choose the Republic of Gamers, ROG, as their defining gaming destination.
The best AAA games for the ROG Ally and ROG Ally X
The ROG Ally is a new breed of handheld, capable of handling large-scale AAA games with great performance. Here are some of our top games for the system.
ROG Travel has assembled a legendary cast for its new ROG Xbox Ally video
ROG Travel is back in action with a zany new video to get folks aboard the ROG Xbox Ally hype train.
The ROG Raikiri II Xbox Wireless Controller is your next-gen premium gamepad for console and PC
From your desk or your couch, the ROG Raikiri II Xbox Wireless Controller is perfect for your PC, Xbox, or ROG Xbox Ally.
Four slick ROG PC gaming battlestations to model your setup after
Check out some of the coolest gaming PC battlestations assembled by ROG fans.
