Guide: Install X-Socket II on Rampage V Extreme
X-Socket II
As you would expect from ROG, there are plenty of extras which come included in the box. Rampage V Extreme makes incredible overclocking a cinch, and for those for you who want even more out of it; like having the bragging rights to breaking the 5GHz barrier. For that you are likely to need this - the X-Socket II.
The standard LGA2011-3 socket comes with metal screw-threads pre-fitted in the socket holes of the default back-plate. This means compatible air or LCLC (Low-Cost Liquid-Cooling) coolers can be screwed in securely.
X-Socket II is designed to replace the LGA2011-3 back-plate with one that is much smaller, leaving the motherboard holes free from the pre-fitted screwed. Now your water cooling blocks, or extreme cooling pots for LN2/dry ice can easily be bolted onto the motherboard directly.
Changing the back-plate is straightforward but let's go through it anyway, because like attempting anything for the first time; it's good to be well prepared.
Don't be Overzealous
Always have a place with ample space to work, and soft covering on the desktop. Dropped motherboards, scratched tables, damaged pins or flying screws happen far more often than necessary (and the guys in our service centers know the difference between a defective motherboard and a dropped one).
Out of the Box
This is how the socket opens, it won't matter if you change it so that it opens from the other end. Just don't try to put it on sideways.
This is the default back-plate as it comes out the box, for compatible air or LCLC coolers.
Loosen Screws
Let's get started by loosening the screws. You won't need to waste your time removing all four screws. (Leave the socket cover on just to be on the safe side).
After you loosen the screws with the Allen key, we found it's faster to unscrew by hand and eliminates the risk of slipping and scratching up the motherboard.
Remove Socket and Default Back-plate
Exercise extreme care when removing and replacing the bracket so you don't touch the CPU pins in the socket.
Replace with X-Socket II Back-plate
Secure the Screws
Like how you removed the screws, just use your hands to screw the X-Socket II in again.
Tighten the Screws
When tightening the screws start on opposite corners to make sure the socket is exactly where it should be and not over-tightened on one corner first.
Transformation Complete
Now you have a Rampage V Extreme with X-Socket II and your OC limits are beyond the realms of mere mortals.
Popular Posts
ROG Strix vs Extreme vs Apex vs Hero: What's the difference between ROG gaming motherboards?
When we launch a new generation of motherboards, we don’t just design one model and expect it to meet everyone’s needs. We give you a broad range of options from our ROG Maximus, Crosshair, and Strix lineups so that you can find the board for your next build.
Install up to seven M.2 SSDs on one motherboard with new ROG M.2 PowerBoost tech
Here's how ROG M.2 PowerBoost allows you to install more M.2 drives in one system while enjoying more stable performance.
ROG Z890 motherboard guide: meet the new contenders for your next gaming rig
New ROG Maximus and ROG Strix Z890 motherboards stand ready for your Intel Core Ultra (Series 2) CPU.
New Z790 motherboards from ROG pave the way for 14th Gen Intel Core CPUs
WiFi 7 support, more fast storage, front-panel device charging, intelligent controls — our latest Z790 motherboards have it all.
New Z790 motherboards from ROG pave the way for next-gen Intel Core CPUs
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
AMD has released two new processors with 3D V-Cache technology: the Ryzen 9 7950X3D and the Ryzen 9 7900X3D. ROG and TUF Gaming X670 motherboards will provide a rock-solid foundation for these new top-tier chips.
