Front Base Upgrade Guide For Maximus VII Motherboard Owners
Are you an ROG Front Base owner who just upgraded to a Maximus VII motherboard (Z97), or, if you bought a Front Base shortly after the Z97 launch you'll very likely need to update its firmware. You can tell because it is missing a sticker behind the LCD panel:
If you DO have a sticker - you're fully compatible! Plug in right now and enjoy!
How to update your ROG Front Base to support Maximus VII motherboards
1) Dig out the USB Q-Connectors from your motherboard box:
2) Plug it into the Front Base cable as shown below. 3) Install the Front Base into your PC 5.25 inch bay and wire up the SATA power cable. 4) Then plug the Front Base cable with Q-Connector into any USB 2.0 pin-out on the motherboard.
5) Turn on your PC. 6) Download these update packages from the Front Base web page:
- ROG Front Base FW Update V1.0.3.3 for Windows 7/8/8.1 32bit & 64bit.
- ROG Front Base Firmware V36
7) Follow the steps to complete the firmware update.
- Open the FW update tool
- Choose the “WB035v35.h00” file where you extracted the three files
- Press Start
- When finished, it will show “ROG Front Base update –Pass”
- Turn off the system and remove the AC power for at least 5 seconds
8) Remove the Q-Connector from the Front Base cable, returning it to the ROG-EXT connector on the motherboard. Now use your PC with Front Base as normal!
Popular Posts
ROG Strix vs Extreme vs Apex vs Hero: What's the difference between ROG gaming motherboards?
When we launch a new generation of motherboards, we don’t just design one model and expect it to meet everyone’s needs. We give you a broad range of options from our ROG Maximus, Crosshair, and Strix lineups so that you can find the board for your next build.
Install up to seven M.2 SSDs on one motherboard with new ROG M.2 PowerBoost tech
Here's how ROG M.2 PowerBoost allows you to install more M.2 drives in one system while enjoying more stable performance.
ROG Z890 motherboard guide: meet the new contenders for your next gaming rig
New ROG Maximus and ROG Strix Z890 motherboards stand ready for your Intel Core Ultra (Series 2) CPU.
New Z790 motherboards from ROG pave the way for 14th Gen Intel Core CPUs
WiFi 7 support, more fast storage, front-panel device charging, intelligent controls — our latest Z790 motherboards have it all.
New Z790 motherboards from ROG pave the way for next-gen Intel Core CPUs
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
AMD has released two new processors with 3D V-Cache technology: the Ryzen 9 7950X3D and the Ryzen 9 7900X3D. ROG and TUF Gaming X670 motherboards will provide a rock-solid foundation for these new top-tier chips.
