Upgrade Guide: ROG GL552
While the world is wanting thinner and lighter laptops, it's easy to forget that for a laptop not much larger in size you can usually get the same great specs or better for less money. Not only that, there are generally more ports, no need for external optical drives, the ability to play games or do 3D rendering, best of all - you have room for upgrades! Let's take a look at the ROG GL552 which can be configured with up to a Core i7 processor, 16GB of DDR3L memory, and Nvidia GeForce GTX 950M graphics. Let's see what you are able to upgrade. First, simply unscrew the two screws at the top of the back panel. Lift it up 45° (do not lift it up past 90°) and slide it out upwards.
After removing the back cover, you will see three compartments where you may be able to upgrade (depending on what you already have). You are able to fill up the two slots for memory (up to 16GB), an M.2 slot for PCIe SSDs (best for installing the OS onto), and a 2.5" hard drive bay for even more (HDD) or faster (SSD) storage.
Up to two 8GB sticks of DDR3L (it's important to know L denotes Low-Voltage in case you somehow manage to find sticks of DDR3, which will not work since they are not dual voltage capable) SO-DIMM memory for a total of 16GB. Below you can see two free slots, one is stacked on top of the other so make sure you install the bottom module first. Align the pins to make sure you have the module the right way up, insert the memory into the slot angled at about 30°, use your thumbs and press evenly on both sides to make sure the module goes all the way into the slot, finally, push the top of the module down towards the motherboard until both of the locks on the sides click into place. Repeat the process for the other module.
It's highly recommended to install your OS in the M.2 SSD (even if you already have a SATA III SSD in the 2.5" bay) if you like speed. Installation is as easy as unscrewing the little screw (see below), inserting the M.2 SSD into the slot and pressing down towards the motherboard, and then securing that screw again.
Next to the M.2 bay is the 2.5" hard drive bay, there are four screws (shown in red) you need to remove first.
After removing the screws, slide the bracket to the left (as in the picture below), replace the hard drive with a new one by removing the screws on the bracket. Make sure to purchase a new drive with a SATA III interface (not that you can find an IDE one nowadays, but get SATA III supporting 6Gb/s for best performance), also make sure to put the new drive in the bracket the right way and screw it back in.
Replace the back cover and voila! A new computer! Almost.
*** Please take care when upgrading, any damages caused will not be covered by warranty. If you run into any issues, remember to revert the laptop to its default configuration (what you purchased) before sending it in for RMA. ***
Popular Posts
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
