ROG Connect And RC Bluetooth Guide
ROG Connect
This is a guide to show you step by step how to setup your ROG Connect and RC Bluetooth. For those of you that don't know about ROG Connect, its pretty much the coolest invention ever! You can remotely control and overclock your system on the hardware level. There is no software tweaking through windows OS, everything is handled directly on the iROG chip changing settings in the BIOS real time!
ROG Connect is pretty straight forward: Download the latest ROG Connect software and install it on your netbook or notebook. connect the ROG Connect USB cable from the notebook and to the ROG connect USB port:
Here we have a Crosshair IV Extreme, but it will work on all models with ROG Connect support. Before opening the ROG Connect application, you need to press the ROG Connect button. It will light up green when on. Then go ahead and open up the program on your notebook and you are ready to go.
As you can see here, we have changed the value of the CPU bus speed to 214, then hit apply.
And here is our result. This app is in the AI SUITE II. It can also be verified through CPU-Z.
ROG Connect features and functions:
[gallery include="" size="medium" link="file" template="file-gallery"]
RC Bluetooth
Note that RC Bluetooth only comes in the ROG Extreme models such as the Maximus III Extreme, Rampage III Extreme, Crosshair IV Extreme, and Maximus IV Extreme.
In this setup, we will show you how to connect using an Android phone. First you should download the latest drivers from the ASUS support site.
If you have an Android phone, you should download the program called Astro file manager from the marketplace (it's free!)
Be sure to have the Bluetooth module on your Extreme board:
We will attempt to transfer your RC Connect files to your phone over Bluetooth, so add new connection:
Be sure to have your phone on discovery mode:
Find your phone from the search results:
Click on wireless transfer:
Click on your phone:
Add in the entire zip file. Attempting to just add the apk file will not transfer:
Accept the file transfer:
Which leads to:
Success!
Open the folder:
Open the Android folder:
Click on the install file:
Then install:
Before you open the app, be sure to turn on the RC Connect button which should light up blue. You do NOT need to turn on the ROG Connect button.
Once the ROG app installs, open the app and press the settings button. Click on devices:
you should be able to find RC bluetooth and connect to it.
If all goes well, you should be connected and should see this menu pop up. you are not connected.
here are some shots in action. changing the bus speed to 207MHz and adjusting the CPU speed in real time on the system through the hardware.
And the result:
Other things you can monitor through your droid:
And adjust your display settings:
Let us know how you get on in the forums and on ROG Facebook!
This article was originally written by Brian @ ASUS.
Popular Posts
The ROG Raikiri II is my new go-to game controller — and I can’t put it down
I'm a PC gamer who plays on the couch — and the new ROG Raikiri II is the lynchpin of my living room battlestation.
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
