The G750JH Customized GTX 780M Graphics Card And Cooling
The G750JH is more than just a G750 with a new GTX 780M swapped inside; the ROG engineers had to make significant customizations in the chassis, cooling and even down to the core graphics PCB itself! Let's start with the the reason why most are interested in the G750JH: the new GTX 780M. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] This is not a standard GTX 780M, the PCB is redesigned by ASUS engineers to be significantly bigger, which affords more components and more space between them too. Together this improves the provision of power, reduces EMI and the extra space aids cooling. In all, this GTX 780M is more tolerant and reliable. It's 3-phase power design (the entire PCB to the right of the memory chips) consists of 2-up, 2-down MOSFETs and upgraded, high-performance Tantalum capacitors. The 4GB of memory is supplied by 16 5GHz GDDR5 chips split between back and front sides, with the 1536-core'd GTX 780M in the middle. All that power needs to be cooled, and as you'd expect, this beast runs hotter than the lesser graphics cards, so needs extra cooling. Firstly let's look at the heat-plate that covers the entire PCB:
As you can see below, everything significant is cooled to ensure it runs smoothly. As with all G750 [and older G5s, and G4s etc] the graphics card is cooled separately to the CPU. With two heatpipes directly to the GPU core and another dedicated to the power hardware, no area is left out and it can quickly draw away heat to the fan. And yes, even the heatsinks are ROG branded!
At the other end of the heatpipe the fans and heatsinks are sufficiently upsized to cool it all. The example below is for CPU and GPU; the thicker fan and heatsink are the same for both, exhausting at either side of the rear of the G750. [gallery include="" size="medium" link="file" template="file-gallery" columns="2"] The double-size heatsink is cut to match the chassis size exactly, which means the chassis enlargement has been minimized to keep its profile and weight as slim as possible.
Popular Posts
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
