EK Water Blocks Releases New Maximus VI Formula Water Block Kit
After recently releasing a water block kit for both the ASUS Maximus VI Gene and the Maximus VI Hero motherboards, and as an alternative to the ROG Fusion Thermo, EK has now released a new water block kit for the Maximus VI Formula motherboard and it still fits under the ROG Thermal Armor!
The EK-FB KIT ASUS M6F features the southbridge (PCH) block as well as the one for power regulation module, VRM/MOSFETs. When installed on the ASUS Maximus VI Formula and paired up with the ROG Thermal Armor, the EK-FB KIT ASUS M6F, gives the Maximus VI Formula a sleek and clean look as well as prepare it for some serious overclocking.
As it was the case with previous EK Water Blocks, this one is also based on a high flow design. Both blocks are made of nickel plated electrolytic copper while the top part is made of quality PM Acetal or acrylic glass material, depending on the version (as shown below).
The new EKWB EK-FB KIT ASUS M6F will be available in Nickel and Acetal+Nickel versions, both with the same €89,95 price tag. Both are already available at EK Webshop and Partner Reseller Network.
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
