Guide: Install M.2 PCIe SSDs in RAID 0 for Speed
M.2 PCIe SSDs are capable of being twice as fast as SATA SSDs, and like graphics cards in SLI or CrossFire; you can drop in another for even more performance! If you are interested in building them in RAID 0 (Stripe) configuration on your ROG or ASUS Z170 motherboard, here is a step-by-step guide to get you set up in no time! For this guide, the ASUS Z170-DELUXE motherboard is being used to demonstrate, the same process can be used for other applicable ASUS and ROG motherboards such as the ROG Maximus VIII Extreme.
Two Samsung SM951 PCIe SSDs were used (one in M.2 Socket, other in ASUS Hyper M.2 X4 Mini Card).
EZ Tuning Wizard
There are two ways to do the RAID configuration; the easy way is to use EZ Tuning Wizard.
First enter the UEFI BIOS, then press F11 to get in and simply go through the process.
After creating the RAID, remember to select X4 Mode for best bandwidth support (varies by model). And disable CSM if you plan on installing the OS into this RAID array (highly recommended for performance!).
Manual Configuration
The other way to do your RAID configuration is not as simple but not very complicated either. For those of your keen to learn, you can try to do it manually. For advanced users, there are more options available, such as the size of partitions.
First, from the UEFI BIOS, you need to select RAID Mode.
Next, Enable all RAID support (M.2, SATA Express and PCIe16_3).
It is very important to select X4 Mode for best bandwidth support (varies by model).
And disable CSM if you plan on installing the OS into the RAID device (highly recommended for performance!)
Alternatively, you could just select UEFI Driver First from boot options.
Now head to the Advanced page and look for the IRST (Intel Rapid Storage Technology) option.
From there you can create or delete RAID volumes easily.
Remember that for the SSDs which you plan to RAID with, select X for each one (to mark them as selected). RAID Level should be in RAID 0 (Stripe) configuration for speed (RAID 1 (Mirrored) offers reliability rather than performance).
Voilà! The RAID volume has been created.
For those of you looking to increase the overall Windows experience by installing the OS to the RAID array, during the OS installation you will need to install the driver. Just download and copy onto a USB drive, use the file iaStorAC.inf to load the driver. When loading the driver it should look like this.
After the driver is installed, you can create or delete partitions however you like.
Here is a screenshot after the OS installation.
After you have installed all the latest drivers, you are ready to run some benchmarks to check out how awesome your rig is!
Note: if you do decide on using RAID 0, it is recommended to have an uninterruptible power supply (UPS - the other kind). Sudden power cuts can sometimes be harmful to hard drives. In the unlikely event when one disk in a RAID 0 array fails, the whole array fails. If you have important data you can't live without, you can try RAID 1 (total storage=one of the disks), or keep using RAID 0 and backup in the cloud, a router with file-sharing capability (so you don't need to buy a router and a NAS), optical or other storage options.
Popular Posts
How to upgrade the SSD and reinstall Windows on your ROG Ally or Ally X
ROG Strix vs Extreme vs Apex vs Hero: What's the difference between ROG gaming motherboards?
When we launch a new generation of motherboards, we don’t just design one model and expect it to meet everyone’s needs. We give you a broad range of options from our ROG Maximus, Crosshair, and Strix lineups so that you can find the board for your next build.
Install up to seven M.2 SSDs on one motherboard with new ROG M.2 PowerBoost tech
Here's how ROG M.2 PowerBoost allows you to install more M.2 drives in one system while enjoying more stable performance.
ROG Z890 motherboard guide: meet the new contenders for your next gaming rig
New ROG Maximus and ROG Strix Z890 motherboards stand ready for your Intel Core Ultra (Series 2) CPU.
New Z790 motherboards from ROG pave the way for 14th Gen Intel Core CPUs
WiFi 7 support, more fast storage, front-panel device charging, intelligent controls — our latest Z790 motherboards have it all.
New Z790 motherboards from ROG pave the way for next-gen Intel Core CPUs
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
AMD has released two new processors with 3D V-Cache technology: the Ryzen 9 7950X3D and the Ryzen 9 7900X3D. ROG and TUF Gaming X670 motherboards will provide a rock-solid foundation for these new top-tier chips.
