PC Mod: Phantom Noir - Using Sabertooth P67
While we don't normally put Sabertooth stuff on ROG (this is that 10% we mentioned before), when we do, we'll always make sure it'll be something you guys want to see!
PC mods are a real labor of love that takes serious effort to plan and construct, and if you love your mods neat and minimalist - 23RO_UK and his NZXT Phantom definitely has the answer!
At its heart is the ASUS Sabertooth P67, using the Thermal Armour to fluidly mix it into a stealthy watercooled black and white themed case design. Check out the finished result below (and more on page 4):
We've copied some of the worklog pictures and eye candy here, but for the full run-down and background, checkout the bit-tech project log. In the meantime, if you also spot any ROG mods or are doing one yourself - drop us a note in our case modding forum! The best ones will be featured on our front page (with makers permission, of course).
Phantom Noir Project Log
From the top: one NZXT Phantom:
Now stripped of its sides and plastics:
[gallery include="" size="medium" link="file" template="file-gallery"]
The first watercooling parts include the two radiators and a Koolance pump-reservoir combo:
The Phobya radiators with Bitspower barbs and?polished plates on top:
How all three go into the front of the case: that's pretty much a perfect fit!
Measuring out the foam to isolate the mounting bracket from the case. This reduces the transferred vibration from the pump.
Final measurements before cutting the base to mount everything. Remember the golden rule: measure twice so you only need to cut once!
How about this for something different - an internal facing fan controller. Let's see how that turns out..
Next the CPU pipes get plugged in with shutoff valves mid-way up.
With clips mounted on the motherboard tray, this keeps the dark tubing neat.
Component fitting to check the space, then onto cable tidying:
That's better! Did you notice the internally mounted bay covers and fan controller?
Stealthing the side panel of the 5.25in bays and PSU:
The finished result:
And in the dark, it looks even better thanks to the white LED fans:
Thanks 23RO_UK for your awesome mod!?
Let us know your thoughts in the forums.
Popular Posts
Can RGB improve your gaming? ROG Lab says ‘results inconclusive, but it sure looks awesome'
ASUS Republic of Gamers (ROG) is undertaking a new ROG Lab initiative designed to scientifically settle once and for all the question of how RGB lighting affects gaming performance.
The ROG Xbox Ally takes the field at the first ever Xbox Bowl college football game
I’m not sure I ever expected to see Master Chief perform the coin toss of a college bowl game, nor watch Peely the Fortnite Banana conduct a marching band. But that’s just a small portion of what I got to witness at the first-ever Xbox Bowl.
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
