Project: Lian Li PC-U6 Nautilus by RebootTech
Micro ATX builds are quite rare; watercooled micro ATX builds even more so. So what about a watercooled, micro ATX build in one of Lian Li's stunning and rare, PC-U6 Nautilus chassis? Well that's exactly what Arizona based modder RebootTech has done. He's managed to cram a Maximus IV Gene-Z/Rev 3, a GeForce GTX 560 Ti, a custom sleeved power supply, two radiators and a 3/8" diameter watercooling loop into a case that really isn't designed or shaped for it, while still keeping it color coordinated and very clean. While acrylic windows are nothing new, this one was especially needed to replace the original perforated mesh in the side panel, in order to appreciably show off its insides. Good job all round!
Build Pictures
[gallery include="" size="medium" link="file" template="file-gallery"]
Finished Pictures
[gallery include="" size="medium" link="file" order="ASC" orderby="menu_order" template="file-gallery" columns="2"] For the full project log, head over to bit-tech.net. Great work Drew!
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
