Project Flipmode by Pascal
Pascal is a 22 year metalworker/welder veteran from the Netherlands, so there's few people more qualified to make awesome, scratch-build PC cases. In Flipmode, Pascal has twisted the typical motherboard tray and created a minimalist mod that focuses on a watercooled ASUS P7P55D motherboard as its powerhouse, while the rest of the kit is entirely hidden underneath. The materials used are a combination of steel and aluminum and stainless steel. We've rounded up the general process here, but there are far more pictures of the build process over in the bit-tech forum thread.
Initial Design
Constructing the main box
All the steel parts were cut and welded together, then the corner welds were cleaned up. Make sure its absolutely 90 degrees! [gallery include="" size="medium" link="file" template="file-gallery"]
Making the Flipdoor hinge
The hinge was inspired by Koenigsegg car doors that pop outwards then upwards. Pascal designed and built the hinge himself from the CAD drawing below: [gallery include="" size="medium" link="file" template="file-gallery"]
Preparing the motherboard tray
With a small bracket set into the back plate, Pascal laser cut the motherboard tray to include all the holes required for the fans. After some 90 degree bends in the right places it was dropped in: [gallery include="" size="medium" link="file" template="file-gallery" columns="2"]
Testing a motherboard fits
Preparing the front panel and top grill
Wiring up the fan controller and PSU
Adding watercooling
Painting the fans to match
Cutting a hole for the PSU
Adding the internal display
Updating the Flipdoor hinge
Two tests for different case feet
Sending away to be painted
The Finished Flipmode!
[gallery include="" size="large" link="file" template="file-gallery" columns="1"] [gallery include="" size="medium" link="file" template="file-gallery"]
Popular Posts
ROG powers the pros as the official PC sponsor of the LCK Finals Hong Kong
At ROG, we’re all about gamers competing at the highest level. That’s why we’re proud to be the official PC sponsor of the LCK Finals Hong Kong.
Get Resident Evil Requiem when you buy an RTX 50 Series graphics card, laptop, or desktop from ASUS and ROG
Unlock the latest chapter of the Resident Evil saga when you snag a GeForce RTX 50 Series graphics card, ROG laptop, or ROG prebuilt desktop.
OpenClaw on the ROG Ally: turn your handheld into a fully local AI assistant
OpenClaw is an always-on agentic AI assistant that can do just about anything, all on a piece of hardware you host yourself.
Boosteroid adds official ROG Ally series support for optimized handheld cloud gaming
Boosteroid has partnered with ROG to make ROG Ally series handhelds the optimal way to stream all your games on the go.
Can RGB improve your gaming? ROG Lab says ‘results inconclusive, but it sure looks awesome'
ASUS Republic of Gamers (ROG) is undertaking a new ROG Lab initiative designed to scientifically settle once and for all the question of how RGB lighting affects gaming performance.
The ROG Xbox Ally takes the field at the first ever Xbox Bowl college football game
I’m not sure I ever expected to see Master Chief perform the coin toss of a college bowl game, nor watch Peely the Fortnite Banana conduct a marching band. But that’s just a small portion of what I got to witness at the first-ever Xbox Bowl.
