The ROG Strix GeForce RTX 5070 Ti brings next-gen style and power to PC gamers everywhere
ROG Strix components are built for top-shelf gamers who want power with a “wow” factor. That's why our ROG Strix GeForce RTX 5070 Ti packs incredible performance inside a gorgeous exterior that tells the world you play hard. If you're building a PC designed to radiate gamer style and crush upcoming AAA titles, this rockstar card fits the bill. Elevated by NVIDIA’s latest GPU architecture and our next-level thermal design, the ROG Strix GeForce RTX 5070 Ti will fuel your ambitions and look good doing it.
The power to play tomorrow’s most demanding games
The ROG Strix GeForce RTX 5070 Ti is ready to play whatever titles you throw at it thanks to a unique blend of NVIDIA GPU power and our own cutting-edge card technology.
You'll get a host of high-tech perks inside the ROG Strix GeForce RTX 5070 Ti thanks to NVIDIA’s Blackwell architecture. This includes 4th generation RT cores for unparalleled ray tracing performance. You’ll also score neural shaders that compress game textures, minimizing memory usage while maximizing real-time visual luster. And with this card’s whopping 1406 AI TOPS, you’ll be well prepared for AI-driven processes, including the latest improvements in NVIDIA DLSS 4 Super Resolution, Ray Reconstruction, and Frame Generation. And thanks to its 5th generation Tensor Cores, your 5070 Ti sports Multi Frame Generation for a visually smooth experience in many AAA games, even with the graphics quality settings cranked.
The ROG Strix GeForce RTX 5070 Ti packs a hefty 16GB of GDDR7 VRAM. This efficient, high-bandwidth memory surpasses GDDR6 to ensure the smoothest gameplay at high framerates and high resolutions. GDDR7 VRAM also helps accelerate video editing processes and 3D rendering timelines, in case you’re into content creation. With 16 gigabytes of GDDR7 in your card, you’ll have the necessary video memory for today’s games as well as tomorrow’s. You’ll also have the next-gen clock speeds you need. The ROG Strix GeForce RTX 5070 Ti runs at 2452 MHz in default mode and 2482MHz in OC Mode.
The card also features Dual BIOS support, letting you easily switch between pushing performance to the limit or having an ultra-silent unit. When you want maximum power, you’ll have it, and when you need quiet time, the 5070 Ti will oblige.
If you want to tinker with your card’s performance even further, download our GPU Tweak III software. It'll provide an in-depth look at your ROG Strix GeForce RTX 5070 Ti's specs and let you control individual GPU parameters. To learn more about the software’s easy overclocking utilities and real-time performance monitoring features, check out our GPU Tweak III guides.
Incredible thermal performance for peak gaming
The ROG Strix GeForce RTX 5070 Ti comes with a host of thermal solutions to keep hardware cool and quiet while you game. With these innovations, you’ll get maximum in-game performance, minimal card heat buildup, and low noise output.
The ROG Strix GeForce RTX 5070 Ti’s three Axial-tech fans push up to 31% more air through the card than standard fans thanks to their long blades. A Phase-Change GPU Thermal Pad revolutionizes efficient heat transfer to ensure your card stays healthy and enjoys a long lifecycle. The MaxContact vapor chamber also helps here, more efficiently distributing heat so your card stays cool while keeping noise down. And 0dB technology means that when you're not playing hardcore games, the card's fans will shut off to give you a truly silent experience.
Style fit for a gaming king
There’s no greater way to tell the world you’re a ride-or-die PC gamer than ROG flair. That’s why the ROG Strix GeForce RTX 5070 Ti’s visual language is tuned to make your machine a spectacle.
Its vented exoskeleton's angular aesthetic proudly declares you’re harnessing a cutting-edge card. The ROG fearless eye logo makes multiple appearances, ensuring no matter what angle the card’s observed from, folks will know you’re part of the Republic. And, of course, this stunner is loaded with RGB to glow up your case from the inside.
The top of the card’s shroud uses semitranslucent plastic to amplify that RGB flair. The plastic picks up and diffuses your card’s illumination, producing a radiance that’ll set the style bar for your PC’s other components. And thanks to Aura Sync, you can effortlessly customize and synchronize this card’s lighting so your compatible parts all match up. If you’re after a modern classic that makes it clear you’re a proud gamer, the ROG Strix GeForce RTX 5070 Ti is a winning choice.
A graphics card that’s built to last
Beyond this card's thermal efficiency, the ROG Strix GeForce 5070 Ti has a host of other features designed to give it a long-lasting lifespan. Take its premium power delivery: with 15K capacitors and digital power control, expect stable, reliable power delivery to the GPU. This card will smooth out voltage fluctuations to keep your gaming experience at its best.
For internal protection, the circuit board features a protective PCB coating. This prevents moisture, dust, and debris from causing short-circuits. Whether you’re gaming in a humid or dusty environment, your card will keep on going.
To provide even more durability, the card is manufactured with Auto-Extreme technology that solders everything in a single pass. This minimizes production strain on your card and enhances durability. Plus, with ASUS GPU Guard, your GPU has heightened resistance to crack damage and benefits from uniform mounting pressure. Put these efforts together, and you have a graphics card that’s forged to endure.
What’s the right PSU for an ROG Strix GeForce RTX 5070 Ti?
If you want your system to run well, you'll need a PSU with the capacity to safely power your graphics card. That's why we recommend the ROG Strix 850W Platinum if you’re going with an ROG Strix GeForce RTX 5070 Ti. The power supply is built for next-gen gaming rigs with its PCIe 5.0-ready design and ATX 3.1 compatibility.
The PSU’s GaN MOSFET ensures efficient power delivery through an optimized internal layout. That, coupled with the unit’s hefty ROG heatsinks, keeps the ROG Strix 850W Platinum’s noise level and temperatures down no matter how hard you’re gaming. And the PSU’s intelligent voltage stabilizer technology means you’ll get unwavering performance even when pushing your PC to its limits.
We’re just scratching the surface of what this PSU has to offer. Its etched modular cables make DIY PC cable management a breeze, its CPU power connector simplifies the installation process — the list of perks goes on and on. This is a feature-rich PSU with a 10-year warranty so you can feel confident about your purchase.
Depending on your setup's specifics — CPU model, overclocking status, types of plugged-in peripherals — you may need even more juice. Use our PSU wattage calculator to find out what you need for your rig. And to learn more about your options, here's our rundown of the best power supplies for your RTX 50 Series graphics card.
ROG Strix, where aesthetics meet performance
If you’re hunting for a strong graphics card with an eye-catching exterior, the choice is easy. The ROG Strix GeForce RTX 5070 Ti is unrivaled when it comes to 5070 models that pack a punch both inside and out. So, when it’s time to refresh your rig, make a meaningful upgrade. The ROG Strix GeForce RTX 5070 Ti is on shelves now, ready to take your gaming PC into the future.
Auteur
Popular Post
Introducing the ROG Xbox Ally and Ally X: ROG and Xbox team up to deliver the best in handheld gaming
Elden Ring on the ROG Ally: performance guide & best settings for Shadow of the Erdtree
How to increase the ROG Ally's VRAM allocation
Armoury Crate operating modes explained: Silent vs Performance vs Turbo vs Windows
Air vs Liquid Cooling for the RTX 5090: Are AIO GPUs better?
Derniers Articles
The ROG Matrix GeForce RTX 5090 celebrates 30 years of gaming innovation
One graphics card, 30 years of legacy. Here's how the new ROG Matrix learns from the past while forging its own path into the future.
Our ROG Strix GeForce RTX 5070 Ti packs incredible performance inside a gorgeous exterior that tells the world you play hard.
Rizz up your rig with the golden ROG Astral GeForce RTX 5080 Dhahab CORE OC Edition
ROG Astral graphics cards are built to take style and performance to new frontiers. The ROG Astral GeForce RTX 5080 Dhahab CORE OC Edition is no exception.
ROG and DOOM: The Dark Ages collide in the ROG Astral GeForce RTX 5080 OC DOOM Edition graphics card
Bold gaming performance meets the iconic style of the DOOM Slayer in the form of one unconquerable graphics card.
ROG Astral vs Strix vs TUF vs Prime: which ASUS graphics card is right for you?
When you go to buy a new graphics card, you might have an idea of which GPU you want, but picking a model is tougher. ASUS and ROG offer a number of variants to provide options that fit your build (and budget) best.
The NVIDIA GeForce RTX 50 series of GPUs has landed, and to usher in this new generation of graphics performance, we’re launching a new line of graphics cards.
