12-11-2012 04:13 PM - last edited on 03-06-2024 06:36 PM by ROGBot
12-11-2012 04:39 PM
12-11-2012 04:50 PM
Chino wrote:
Let's start with your complete system specs, please. Try to make it as detail as possible.
12-11-2012 05:54 PM
12-11-2012 06:04 PM
Myk SilentShadow wrote:
Since this is a brand new setup, you need to press F1 to access the BIOS. When you get to the American Megatrends screen on bootup, it should say near the bottom of the screen...somewhere, that you need to hit F1
12-11-2012 06:38 PM
12-11-2012 07:18 PM
oldbrave wrote:
OK, lets see if wee can't get you so's your just a little bit crazy! 🙂
Set up your system with just the CPU, one stick of memory in the farthest slot from the processor, the 128Gb SSD in sata slot 1. just one video card in the top PCI-Ex16. if your Keyboard and mouse are USB then make sure that you plug them into a usb 2 connections, not usb 3 !
When you see the post data hit the screen then tap the del key two or three times to get you into the bios.
INFO: you should always set the boot drive up to Sata port 1, just seems to make things go a bit smoother.
ANYWHO give my set up a try and see if you find joy ! 🙂
12-11-2012 07:30 PM
12-11-2012 06:42 PM
Rapid99 wrote:
I wish that was the case 😕
