Ideas for SLeeved Cables???
apocpg
I recently just modded my Carbide 500r case and put in a window instead of the screen/fan combo
now i would like to upgrade to sleeved cables and would like to get some recommendations about brands and sources
http://prntscr.com/720fty
http://prntscr.com/6qsr4g
http://prntscr.com/6ql2tg
7 REPLIES 7
kkn
Level 14
list system ( psu brand )
MOBO:Asus Maximus Hero VII
CPU:Intel i7 4790k
Ram:16gb Gskill Ripjaw
GPU Zotac GTX 960
HD: 2 x 250gb SSD
Cooler Corsair H100I GTX
PSU: Thermaltake 850w
Praz
Hello
Something like this would look good. LC Teleios black, dark gray and dark red.
http://mainframecustom.com/product-category/cable-sleeving/lc-teleios-sleeve/lc-teleios-4mm-sleeve/
49001
Myk_SilentShado
Level 15
I haven't used Teleios sleeving yet, but, I have been using Paracord sold by Mainframe Customs. It's a pain in the rear for a 1st time sleever, but I still highly recommend it! 🙂
Nate152
That's a nice looking cable praz posted. There are also extension cables all ready to go in pretty much any color and uv too.
But the downside is they must be used as extension cables, you can't connect them straight to the psu.
http://www.performance-pcs.com/mod-smart-kobra-cables?limit=90
kkn
Level 14
this is custom cables -> http://www.icemodz.com/custom-psu-cables/
and they may cost.
but if you want to buy cables that fits to your PSU? i can not find enny colored ones that is made for that PSU after a quick google.
i have corsair PSU and i can get for mine.
are you going to do it your self or get others to do it?
sectionate
Level 12
http://www.corsair.com/en/power-supply-units/psu-accessories
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
