An inside look at Ben Q’s brass-filled Blanco build
When it comes time for a new computer, you have lots of options. While some people choose the simplicity of buying a pre-built machine off the shelf, enthusiasts often opt to choose every part of their PC for themselves. If you’re a master builder like Ben Q, though, that customization takes on a whole new meaning.
Taking inspiration from his love of architecture, Ben Q set out to craft a PC that was as much a piece of art as it was a powerful gaming rig. With computers becoming such an integral part of many homes, he wanted to build something that wouldn’t merely occupy space, but add to the overall design of a room. What emerged from those ideas became a build that he dubbed Blanco.
The heart of Blanco is an ASUS ROG z390 Maximus Code and an ASUS GeForce RTX 2060. Ben Q rounded out the build with an Intel Core i7-8700K, a 1TB Samsung M.2 SSD, 32GB of TeamGroup’s Night Hawk RGB RAM, and a Seasonic 750W PSU.
Blanco's journey from idea to finished build took more than six months. Ben Q spent the majority of that time working with custom case builder Parvum to achieve his artistic vision. Despite the amount of time it took to get the chassis just right, it wasn’t even the most challenging part of the build. As with any build that includes a custom liquid cooling loop, Ben Q had to spend a significant amount of time figuring out how to get that fluid exactly where he wanted it.
Once you peek inside Blanco’s windowed side panel, it immediately becomes clear why Ben Q spent so much time on the cooling solution. He chose to forgo the off-the-shelf tubing elements in favor of custom gold-plated brass piping. The polished look of the brass shines as a unique centerpiece for the build. Unfortunately, it comes at a cost.
If you’ve never worked with plated brass tubing before, you might not know how delicate it is. Any attempt to bend it is generally met with bits of the plating flaking off, ruining its beautiful shine. Ben Q spent a good deal of time creating a custom jig that allows him to delicately bend and shape the tubes as needed. The end result is an interior that shines brightly without the need for abundant RGB lighting.
Since the complex tubing takes up a majority of the available space in front of the motherboard, Ben Q carefully hid the liquid reservoir on the back of the build. He designed individual channels for the liquid in CAD software, cast them in acrylic, and placed them in the top and bottom of the case. They’re built so seamlessly into the chassis that you’ll miss them if you’re not explicitly looking for them.
Ben Q's final touch for Blanco was a set of custom cables from Mainframe. The white and orange power cables accent the case and copper tubing while still allowing the muted beauty of the ASUS motherboard and graphics card to shine through.
This is the first time we’ve featured one of Ben Q’s custom builds, but it’s far from his first rodeo. You can check out his other designs and keep up to date with his latest projects on his Instagram.
Auteur
Popular Post
ASUS ROG à la Gamescom 2025 : une vitrine d’innovation avec la ROG Xbox Ally, les nouveaux écrans OLED TrueBlack et nos 30 ans, happy birthday s'il vous plaît !
La Revue Gaming d'ASUS - PC portable gamer G752
X670 vs. X570 vs. B550 : quelle carte mère AMD vous correspond ?
Cartes graphiques ROG Strix
ROG STRIX GTX 1080 - Des performances uniques et AURA RGB, Testé par CHINO
Derniers Articles
Ben Q's brass-filled Blanco build fuses a custom case and cooling hardware with ROG components for a one-of-a-kind PC.
Behind The Bunker: A Look At Snef's Combat-ready Black Ops 4 Build
Take a tour of a battle-ready PC created by renowned modder Snef and inspired by Call of Duty: Black Ops 4.
Dans les coulisses de la création du boîtier : Mass Effect Andromeda avec Gizmo2Poche
En ce moment, avec ASUS ROG France, Cooler Master France & EA France mais aussi grâce à nos autres partenaires Crucial France et CableMod, vous pouvez gagner un PC au design unique au monde, entièrement équipé, basé sur le thème Mass Effect Andromeda ! Nous vous invitions dans les coulisses de la création du boîtier.
Gagne ton kit ultime pour explorer la galaxie d’Andromeda !
Participez au concours ASUS ROG et gagnez un lot ultime lié à l'univers Mass Effect Andromeda ! Gagnez le jeu PC en édition super deluxe, un PC customisé, un nomad télécommandé, des goodies et des périphériques ASUS ! N'attendez plus pour participer !!!
Télécharger les fichiers pour l'impression 3D
Créez la vôtre : Projet ASUS impression 3D à découvrir maintenant !
Un Mod hypnotisant : Le ROG Certified H-Tower des Frères Blass
Découvrez l'un des mod les plus réussis de la Gamescom 2016 ! Tout en blanc et bleu, il a été réalisé par les frères Blass à partir du boitier In Win H-Tower.
