EK Water Blocks EK-FC R9-290X Compatible With The R9 290
EK Water Blocks have announced that the EK-FC R9-290X series water blocks are also compatible with reference design ASUS Radeon R9 290 graphics cards, in case you are looking to do some overclocking or simply wanted to change the reference cooler. As both the R9 290X and the R9 290 graphics cards use the same PCB design and even have the same reference cooler. The difference comes from the the GPU Stream Processor count and lower clock speed, so it does surprise that the EK-FC R9-290X series are compatible. It features a very high flow design and can be used with weaker water pumps and features 0.6mm wide microchannel structure that should further improve the heat transfer while not sacrificing the famous low hydraulic restriction design. Available in five different versions - depending on the material used for the top cover - the EK-FC R9-290X is a full-cover water block that directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas, allowing it to remain stable even under high overclocks. In case you already bought the R9 290 or simply can't wait for the ASUS DirectCU II version, EKWB EK-FC R9-290X might be just what you are looking for!  [gallery link="file" columns="4" orderby="title"]
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - ASUS GPU Tweak III: The ultimate tool for advanced GPU tuning
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
