ASUS Announces Xonar U3 Plus, Pocket-Sized USB Sound With Headphone Amp
ASUS continues to grow its popular USB audio line with the new Xonar U3 Plus, an upgrade to the standard U3 that includes a 150-Ohm headphone amp, a DSP with extremely-low latency microphone loop and a full suite of audio enhancements including a dedicated 10-band equalizer featureing five pre-set audio modes (Rock, Rock Pro, Ballad, Ballad Pro, and Special) that have been specially-tuned and calibrated by Xonar engineers, and Stereo Mix and DJ Mix tools.
The U3 Plus is the smaller version of the existing Xonar U5 and gaming-orientated U7 Echelon Edition with Sonic Radar.
Xonar U3 Plus Specs:
- Signal-to-Noise Ratio (SNR): 100dB
- Total Harmonic Distortion + Noise : 0.005% (-110dB)
- Frequency response: 20Hz to 20kHz
- Headphone impedance: Optimized for 32~150Ω
- Interface: USB 1.1 or above bus compatible
- Sample Rate and Resolution: Up to 48KHz @ 16bit
- Connectivity: 1 x 3.5 mm jack analog out; 1 x 3.5 mm jack (Line-In/Mic-In combo); 1 x S/PDIF out (combo with analog out)
- Operation system: 1/8/7/XP(32/64bit)
- Karaoke functions: Music pitch-shifting, vocal cancellation, and microphone echo effects with stereo mix recording (Wave and Mic-in) for online Karaoke or online DJ applications
See the full details in the press release below the pics.
[gallery size="large" link="file" template="file-gallery" columns="2"]
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
