Guide: Building RAID With UEFI
If you've previously followed our UEFI boot/install guide, here's a BIOS guide to the next step: building a RAID array with UEFI.
1. Under the Advanced menu, configure the SATA to [RAID Mode].
2. Under the Boot/CSM section, set [Boot from Storage Device] from [Legacy OpROM First] to [UEFI Driver First], then press the “F10” key to save and exit.
3. Upon the next POST, re-enter the BIOS again, then you will see the following differences in BIOS options:
- For X79 series (Rampage IV), you will find the [Intel(R) Rapid Storage Technology] menu under the Advanced menu, which did not show up before.
- For Z77 series (Maximus V), just press the right key from the [Tool] tab and you will reveal additional UEFI options:
• Now make the desired changes. You can create either create RAID volumes:
• Or delete them:
• Or check the drive status:
After everything is done, press F10 to save and exit, then install 64-bit UEFI Windows onto your RAID array as we described previously.
Enjoy!
Popular Posts
ROG Strix vs Extreme vs Apex vs Hero: What's the difference between ROG gaming motherboards?
When we launch a new generation of motherboards, we don’t just design one model and expect it to meet everyone’s needs. We give you a broad range of options from our ROG Maximus, Crosshair, and Strix lineups so that you can find the board for your next build.
Install up to seven M.2 SSDs on one motherboard with new ROG M.2 PowerBoost tech
Here's how ROG M.2 PowerBoost allows you to install more M.2 drives in one system while enjoying more stable performance.
ROG Z890 motherboard guide: meet the new contenders for your next gaming rig
New ROG Maximus and ROG Strix Z890 motherboards stand ready for your Intel Core Ultra (Series 2) CPU.
New Z790 motherboards from ROG pave the way for 14th Gen Intel Core CPUs
WiFi 7 support, more fast storage, front-panel device charging, intelligent controls — our latest Z790 motherboards have it all.
New Z790 motherboards from ROG pave the way for next-gen Intel Core CPUs
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
AMD has released two new processors with 3D V-Cache technology: the Ryzen 9 7950X3D and the Ryzen 9 7900X3D. ROG and TUF Gaming X670 motherboards will provide a rock-solid foundation for these new top-tier chips.
