Guide: Liquid Cooling Your ASUS ROG Graphics Card - The Easy Way
Chino is at the grand master level on the ROG Guru scale, this ROG Forum member has provided some helpful tips to have you setup with some liquid cooling in your system in no time. Not sure exactly what kind of fittings, connectors and kits are compatible with ASUS ROG graphics cards? Here are some configurations using the ROG Poseidon GTX 980 Ti with DirectCU H2O for hybrid air/liquid cooling (so you don't have to buy an additional waterblock), and standard ASUS graphics cards with aftermarket waterblocks for reference. Now you won't need to shop more than once or return incompatible parts. Read more and find out the difference in performance and temperature by checking out Chino thread.
"Building a custom liquid cooling solution requires time and money, things that not every enthusiast has. But the benefits of liquid cooling are accessible to many users thanks to the existence of AIO liquid coolers. As a matter of fact, they have gotten so popular over the years that nowadays one can find specialized units on the market for cooling graphics card as well. But perhaps the biggest drawback with closed loop liquid coolers is the lack of expandability. If the plan is to cool both the processor and the graphics, the user would need to buy two different AIO liquid coolers to accomplish this task. In the end, this results in spending more money and ultimately requiring more space inside the computer case to accommodate both units.
The ideal situation would be to invest in a single AIO liquid cooler that gives the user the option for expansion. That’s where the new EKWB Predator 360 comes to mind. It’s a 360mm liquid cooling unit that is capable of cooling the processor and graphics card simultaneously. But the most innovative feature is the Quick Disconnect Connector (QDC) that is built into the hoses that allows users to expand their loop without having to drain the whole system."
Popular Posts
How to upgrade the SSD and reinstall Windows on your ROG Ally or Ally X
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
