ASUS Announces Best, Fastest and Most Comprehensive USB 3.1 Solutions
ASUS' USB 3.1 motherboard line-up features new motherboards with two USB 3.1 ports installed on the PCB itself, and existing motherboards with a ASUS USB 3.1 PCIE add-in cards bundled in the package. Both are identified by the /USB3.1 suffix.
For those wanting to upgrade an existing system with USB 3.1 - that PCIE add-in card will also be available separately for compatible motherboards. Note: a BIOS update is sometimes required - see the press release for more details.
New ASUS USB 3.1 motherboards:
- Rampage V Extreme/U3.1 (bundled with add-in Type-A card)
- X99-Deluxe/U3.1 (bundled with add-in Type-A card)
- X99-Pro/USB3.1
- X99-A/USB3.1 (Transfer Express)
- X99-A/USB3.1
- X99-E WS/USB3.1
- Z97-Deluxe/USB3.1
- Z97-Pro(Wi-Fi ac)/USB3.1
- Z97-A/USB3.1
- Z97-E/USB3.1
- Z97-K/USB3.1
- Sabertooth Z97 Mark 1/USB3.1
- B85M-G Plus/USB3.1
- B85-Plus/USB3.1
[gallery include="" size="large" link="file" template="file-gallery" columns="2"]
ASUS USB 3.1 PCIE add-in card compatible motherboards are listed in the press release below. This card is available in two versions: one featuring two Type-A connectors, to retain compatibility with existing USB cables and existing products, and one with a new, reversible Type-C connector.
And an example of performance, or see ASUS USB 3.1 testing from Anandtech, PC Perspective, bit-tech and Kit Guru.
For more information on the background of USB 3.1 technology, read our technical insights here.
Popular Posts
ROG Strix vs Extreme vs Apex vs Hero: What's the difference between ROG gaming motherboards?
When we launch a new generation of motherboards, we don’t just design one model and expect it to meet everyone’s needs. We give you a broad range of options from our ROG Maximus, Crosshair, and Strix lineups so that you can find the board for your next build.
Install up to seven M.2 SSDs on one motherboard with new ROG M.2 PowerBoost tech
Here's how ROG M.2 PowerBoost allows you to install more M.2 drives in one system while enjoying more stable performance.
ROG Z890 motherboard guide: meet the new contenders for your next gaming rig
New ROG Maximus and ROG Strix Z890 motherboards stand ready for your Intel Core Ultra (Series 2) CPU.
New Z790 motherboards from ROG pave the way for 14th Gen Intel Core CPUs
WiFi 7 support, more fast storage, front-panel device charging, intelligent controls — our latest Z790 motherboards have it all.
New Z790 motherboards from ROG pave the way for next-gen Intel Core CPUs
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
AMD has released two new processors with 3D V-Cache technology: the Ryzen 9 7950X3D and the Ryzen 9 7900X3D. ROG and TUF Gaming X670 motherboards will provide a rock-solid foundation for these new top-tier chips.
