EK Introduces Maximus VI Impact Water Cooling Solution
EK Water Blocks has launched its first, total (CPU and motherboard) solution for ROG Maximus VI Impact water cooling, dubbed the EK-FB ASUS M6I. It uses the EK-Supremacy cooling tech on the CPU, while also extending over the Z87 PCH and power regulation (VRM / MOSFETs) vertical module to cool them. It is a very high flow water block that can be easily used with systems using weaker water pumps. "We're excited to introduce our first AIO water block," said Niko Tivadar, EK-FB ASUS M6I main designer and Product Manager of EKWB. "EK-FB ASUS M6I provides sleek design with only two in- and out- water ports which greatly improves the functionality of the unit. Uncompromised CPU cooling is ensured by the use of our award-winning EK-Supremacy CPU water block cooling engine. ASUS® Maximus VI Impact motherboard, paired with our cooling solution, represents the foundation for building the flagship performance small-form factor D.I.Y. gaming machine." The block is made of bare or nickel-plated electrolytic copper (depending on what you select to buy), while the top is a choice between quality POM Acetal or acrylic glass. The clear variants feature two slots for easy installation of 3mm LED diodes (naturally we recommend going red). EK also encloses its EK-LGA 115x TRUE Backplate to ensure even contact with the CPU, as well as to prevent any motherboard warping. [gallery size="medium" link="file" template="file-gallery" columns="2"] (For more pictures see the EK website) It is available in six different versions:
| SKU | MSRP (incl. VAT) |
| EK-FB ASUS M6I | 99,95€ |
| EK-FB ASUS M6I - Acetal | 99,95€ |
| EK-FB ASUS M6I - Nickel | 108,95€ |
| EK-FB ASUS M6I - Acetal+Nickel | 108,95€ |
| EK-FB ASUS M6I - Nickel (Original CSQ) | 108,95€ |
| EK-FB ASUS M6I - Acetal+Nickel (Original CSQ) | 108,95€ |
Popular Posts
ROG Strix vs Extreme vs Apex vs Hero: What's the difference between ROG gaming motherboards?
When we launch a new generation of motherboards, we don’t just design one model and expect it to meet everyone’s needs. We give you a broad range of options from our ROG Maximus, Crosshair, and Strix lineups so that you can find the board for your next build.
Install up to seven M.2 SSDs on one motherboard with new ROG M.2 PowerBoost tech
Here's how ROG M.2 PowerBoost allows you to install more M.2 drives in one system while enjoying more stable performance.
ROG Z890 motherboard guide: meet the new contenders for your next gaming rig
New ROG Maximus and ROG Strix Z890 motherboards stand ready for your Intel Core Ultra (Series 2) CPU.
New Z790 motherboards from ROG pave the way for 14th Gen Intel Core CPUs
WiFi 7 support, more fast storage, front-panel device charging, intelligent controls — our latest Z790 motherboards have it all.
New Z790 motherboards from ROG pave the way for next-gen Intel Core CPUs
The best motherboards for a Ryzen 9 7950X3D CPU from ROG and TUF Gaming
AMD has released two new processors with 3D V-Cache technology: the Ryzen 9 7950X3D and the Ryzen 9 7900X3D. ROG and TUF Gaming X670 motherboards will provide a rock-solid foundation for these new top-tier chips.
