EK Releases Monoblock for ASUS Maximus VIII Extreme & Impact!
EK has released EK-FB ASUS M8E Monoblock for the ROG Maximus VIII Extreme motherboard, and EK-FB ASUS M8I Monoblock for the ROG Maximus VIII Impact. Both are all-in one solutions to provide liquid-cooling for the latest 6th Gen. Intel Core processors and power regulation MOSFETs (also ASM1187e PCIe packet switch on the Maximus VIII Extreme) for overclockers and modding enthusiasts. Each monoblack comes in Nickel or Acetal + Nickel.
The use of monoblocks eliminates the use of multiple waterblocks, and simplifies the assembly process. This is due to less tubing which in turn reduces the possibility of leaks, and less tubing makes assembly significantly easier especially in smaller builds where the motherboard is hard to reach with big hands, or when soft tubing isn't possible due to the acute angles required. Best of all, your build looks much better and less cluttered!
Here is the monoblock for the E-ATX Maximus VIII Extreme, there's no need to remove the ROG armor!
Here is EK-FB ASUS M8I Monoblock for the Mini-ITX Maximus VIII Impact
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
