EK Water Blocks releases Maximus IV Gene and Hero EK-SB ASUS M6G
EK Water Blocks has released yet more water block for ROG's Maximus VI series: this time the Maximus VI Gene and Maximus VI Hero motherboards. Featuring high flow designs as well as a rather unique look, the new EK-SB ASUS M6G is designed for the Z87 PCH on both boards! The EK-SB ASUS M6G fits Gene out-of-the-box, while the Hero it requires re-fitting of the standoffs to alternative mounting holes via supplied mini-wrench.
The high flow design allows it to be used quieter and less powerful water pumps, and will be available in both standard Nickel as well as the Acetal+Nickel version with clear top.
EK Water Blocks also offers the EK-MOSFET ASUS M6G series water blocks for the VRM area on same two motherboards, and will sell it together with the EK-SB ASUS M6G as a Full-Board Kit (FB KIT). According to EK Water Blocks, the new EK-SB ASUS M6G is already available at EK Web Shop or via its partner reseller network with a suggested price set at €24,95 for both versions.
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
