Customized PC Build: Supernova by 8Pack From Overclockers UK
Anyone familiar with the overclocking scene definitely should have heard of 8Pack who is one of the top extreme overclockers in the world, and currently is a holder of numerous world records. 8Pack also represents Overclockers UK so you normally see 8Pack around the Overclock UK forums offering his expertise to fellow forum members on overclocking and other PC hardware related topics. Maybe you know as much as what's written so far, but did you know that 8Pack also has his own line of customized PC builds which are offered through Overclockers UK? 8Pack's latest and greatest customized PC build is the Supernova, the system is packed with some of the highest high-end components, empowering whomever owns this system to have absolute bragging rights. One look at this and you'll know 8Pack doesn't muck about.
Below are the default specifications of this customized build:
- CPU: i7-5960X overclocked to 4.625GHz
- Motherboard: ASUS Rampage V Extreme
- Memory: 32GB 2666MHz Kingston HyperX Predator DDR4
- Graphics: 4 x ASUS GTX Titan X 12GB (reference version)
- Storage: 2 x 1TB Samsung 850 Pro SSD in RAID0 configuration
- Case: Custom Lian Li PC-D600 Series
- Cooling: EK GPU and CPU waterblocks, 1 x XSPX triple 120mm-fan half-height radiator, 1 x Coolgate triple 120mm-fan full-height radiator, Overclockers UK custom SilverStone fans, EK fittings, 2 x Laing D5 pumps, EK Reservoir, chrome-plated copper tubing
- PSU: SuperFlower 2000W PSU
- OS: Windows 8.1 64-bit operating system
Below is a gallery of the Supernova build:
[gallery include="" size="large" link="file" template="file-gallery" columns="2"]
Overclocking.tv also did an up close and personal interview with 8Pack, check out the video below:
[video]https://youtu.be/Xa-qwcACdPQ[/video]
8Pack has also recently attained 3 new world records, for additional details on this news, see the article here.
Popular Posts
See the mammoth ROG Dominus build that takes Intel's 28-core Xeon W-3175X to the Extreme
The ROG Dominus Extreme pushes the boundaries of PC performance in our awesome CES 2019 build.
Breaking world records with the ROG Maximus XI Gene and the Intel Core i9-9900K
Tasked with pushing performance on the Z390 platform as far as possible, we invited the best overclockers to ROG HQ for a week of extreme overclocking.
How to overclock your system using AI Overclocking
AI Overclocking one-click tuning makes its debut on Z390 motherboards and we have a quick how-to guide to get you started.
