Prodigy Projekt - A Watercooled, Overclocked Mini-ITX LAN Monster!
The Mini-ITX form factor has been around since the early 2000's (thank you, VIA), but like a good A-Team episode, come 2012 it finally feels like the plan is coming together. Prodigy Project won't help you quell the lust for a new, sexy little LAN machine, that's for sure, so if you're prone to outbursts of impulse spending I'd stop reading now. Still with me? Good! Now take a look at this:
Constructed by Slovakian boutique PC builder, Tiché PC, this LAN monster features the following hardware:
Here's the spec run down:
- ASUS P8Z77-I Deluxe (Dear Mobo Team: Why no mini-ROG love?? I want to write about SFF more!),
- Intel Core i7-2600K
- GeForce GTX 670 (gotta love that tiny PCB)
- 16GB G.Skill RipjawsX 1,600MHz DDR3
- Crucial M4 128GB SSD
- Seasonic 460FL (fanless!)
- Bit Fenix Prodigy (mini-ITX chassis)
Watercooling:
- Bitfenix Spectre Pro 200mm fan
- 1 x 140 + 2 x 120 Corsair Fans
- HEATKILLER GPU-X3 GTX 670 waterblock
- HEATKILLER Rev. 3.0 LT CPU waterblock
- ALPHACOOL VPP655 Single / TOP Pump
- XSPC EX-240 Dual Fan Radiator
- Phobya Radiator 200mm
- EK Water Blocks EK-Multioption RES X2 - 150 Advanced
- BitsPower / EK / Alphacool / Koolance Hose Fittings + Primochill bits
- Aquaero LT USB fan controller
The Build Gallery
[gallery include="" size="medium" link="file" template="file-gallery"]
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
