ASUS Republic of Gamers Announces Strix RX 480
ROG Strix RX 480 is the next-generation graphics card, featuring the new Polaris 10 from AMD at the core based on a new 14nm FinFET fabrication node (previously 28nm) to bring you a new level of performance with less heat. You'll be hard-pressed to find another card with such performance to run VR (virtual reality) games at this price point.
The GPU (grahics processing unit) comes factory-overclocked to 1330MHz in OC mode with headroom for further tweaking (1310MHz boost clock in gaming mode) and is paired with 8GB of GDDR5 video memory operating at 8GHz on the 256-bit memory bus. This translates to a performance boost of 15% in 3DMark Fire Strike and 19% in the latest games such as DOOM and Hitman compared to reference.
Auto-Extreme and Super Alloy Power II Technology
Just as other ROG Strix graphics cards, only the best components and manufacturing process is acceptable. Auto-Extreme technology employs a 100% automated manufacturing process which requires premium Super Alloy Power II components to be used. The graphics cards produced are consistently higher quality, run quieter, more efficient and cooler which in turn makes them overclock better, be more stable and last longer. The process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50% during production.
Redesigned Power Allocation
Power allocation has been redesigned compared to reference. ROG Strix RX 480 with the use of a custom VRM (voltage regulator module) and PCB (printed circuit board) draws 100% of the GPU power from the 8-pin PCIe power connector (rather than splitting the load between the connector and the PCIe slot). Such a design ensures that the PCIe slot specifications for power consumption is not breached (the card may throttle otherwise).
Exclusive ASUS Features and Technologies
The new GPU together with the DirectCU III cooling solution with triple wing-blade fans results in a graphics card that is three times quieter and 30% cooler than reference, only by having this level of thermal performance can this card incorporate 0dB technology which makes the card completely silent during casual gaming. The matte black shroud and backplate with new Aura RGB lighting which comes with six lighting effects can surely match almost any system. FanConnect technology incorporates two 4-pin GPU-controlled headers, allowing you to control dedicated case fans to cooling the area around the graphics card specifically. GPU Tweak II will provide easy one-click overclocking while a professional mode is still available for advanced users, XSplit Gamecaster is also included to stream or record gameplay.
The ROG Strix series of graphics cards are the only ones with a dedicated HDMI port for VR, rest assured you won't be having any problems connecting up a VR set if you already have an HDMI monitor connected. There are two DisplayPort 1.4, two HDMI 2.0 and a DVI-D port. AMD FreeSync will make sure you're getting smooth gameplay when using supported gaming monitors such as MG248Q, MG28UQ or MG24UQ.
ROG Strix RX 480 will be available worldwide from mid-August 2016. For more info, hit the PR button below.
Popular Posts
The ROG Matrix GeForce RTX 5090 celebrates 30 years of gaming innovation
One graphics card, 30 years of legacy. Here's how the new ROG Matrix learns from the past while forging its own path into the future.
The ROG Strix GeForce RTX 5070 Ti brings next-gen style and power to PC gamers everywhere
Our ROG Strix GeForce RTX 5070 Ti packs incredible performance inside a gorgeous exterior that tells the world you play hard.
Rizz up your rig with the golden ROG Astral GeForce RTX 5080 Dhahab CORE OC Edition
ROG Astral graphics cards are built to take style and performance to new frontiers. The ROG Astral GeForce RTX 5080 Dhahab CORE OC Edition is no exception.
ROG and DOOM: The Dark Ages collide in the ROG Astral GeForce RTX 5080 OC DOOM Edition graphics card
Bold gaming performance meets the iconic style of the DOOM Slayer in the form of one unconquerable graphics card.
ROG Astral vs Strix vs TUF vs Prime: which ASUS graphics card is right for you?
When you go to buy a new graphics card, you might have an idea of which GPU you want, but picking a model is tougher. ASUS and ROG offer a number of variants to provide options that fit your build (and budget) best.
The NVIDIA GeForce RTX 50 series of GPUs has landed, and to usher in this new generation of graphics performance, we’re launching a new line of graphics cards.
