ASUS Announces B150I Pro Gaming/WiFi/Aura, B150I Pro Gaming/Aura and B150M Pro Gaming
We are entering an exciting era of portable computing (and of course gaming!), where people from around the world are united by devices so small it can take the form of a watch with a quad-core CPU, and hardcore PC gaming can be had with a case the size of a shoebox! You first got a glimpse of the ASUS B150I Pro Gaming/WiFi/Aura just last month at CES 2016 in Las Vegas, today it is already being announced along with two other motherboards for small builds - B150I Pro Gaming/Aura and B150M Pro Gaming! These new mini-ITX and micro-ATX motherboards are based on the Intel B150 chipset to support 6th Gen. Intel Core i7/i5/i3/Pentium/Celeron processors with the LGA1151 socket and DDR4 memory (up to 2133MHz). ASUS B150I Pro Gaming/WiFi/Aura and B150I Pro Gaming/Aura come with the latest Aura RGB lighting effects; as well as the effects previously available, there are now Comet, Flash and Dash, Rainbow Wave, Starry Night and Glowing Yo-Yo. If you are not into the RGB lighting effects, ASUS B150M Pro Gaming is available in a slightly larger and more upgradeable micro-ATX form-factor.
All three boards come with support for M.2 SSDs for transfer speeds of up to 32Gbps,
If there's a possibility you may need WiFi, B150I Pro Gaming/WiFi/Aura comes with built-in 2x2 (2T2R) 802.11ac Wi-Fi with Multi-User MIMO (MU-MIMO) for better range and reliability. Later on, you won't need to give up a USB port to get WiFi, on smaller boards there simply isn't that much space for ports.
[gallery include="" size="medium" link="file" template="file-gallery" columns="2"]
[gallery include="" size="medium" link="file" template="file-gallery"]
If you won't be using wireless, you can make use of the Intel Gigabit Ethernet with LANGuard for surge-protection, you still get all the Aura RGB lighting effects plus you can save money to go towards other components.
B150M Pro Gaming
If considering a small build with loads of storage and upgradeability, this has four DDR4 slots for up to 64GB of memory, an extra two PCI Express 3.0 x1 slots, and two more SATA 6.0Gbit/s ports.
There are more back IO USB ports on the B150M Pro Gaming; up to six USB 3.0 Type-A, and up to six USB 2.0 ports.
Hit the PR button below for full specs!
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
