ASUS Announces Strix R9 280 3GB And Strix GTX 780 6GB Gaming Graphics Cards with 0dB Fan Tech
We're proud to announce that the Strix R9 280 and GTX 780 gaming graphics cards have just launched with 0dB fan technology. Yep, in some scenarios they will literally run silent.
The GTX 780 model has double memory: 6GB, while both have 10-phase power design that reduces power noise by 30% and increases efficiency by 15% versus reference designs. The cards are built with DIGI+ VRM and hard-wearing POSCAPs, while the DirectCU-like cooler has been upgraded with '0dB technology'. When the GPU temp is below 65C the card will run in passive mode with the fans turned off. The large heatsink works to efficiently absorb and dissipate the minimal heat generated by low loads, so while you're surfing the internet, watching videos, playing light games - your graphics card won't make a sound.
As the GPU temp hits 65C - say you fire up some intense-FPS action that really pushes your PC - the fans spin up slowly, with lowest setting at 300RPM, and ramp up in direct relation to any increasing temperature in order to maintain best performance.
Ultimately the effectiveness depends on your ambient air temperature; those in hotter/humid countries will find their GPU hits 65C sooner than those in cooler climates, and your case temp; efficient airflow through the case will keep all component temps lower. Have a look at our positive/negative pressure case cooling testing for more ideas.
Hit the PR button below the pics for the full info.
[gallery include="23327,,23327" size="medium" link="file" template="file-gallery" columns="2"]
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - ASUS GPU Tweak III: The ultimate tool for advanced GPU tuning
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
