ASUS Launches VG248QE 24 Inch 144Hz 3D Gaming Monitor
VG248QE
Following the 27 inch VG278HE the new ASUS VG248QE monitor continues the 144Hz trend, but this time in a 24-inch package. It has been purpose-designed for high-performance NVIDIA 3D Vision 2 or 'fast' 2D gaming, where the increased refresh rate gives incredibly smooth on-screen motion.
The VG248QE has a 1920 x 1080 Full HD resolution and an 80,000,000:1 ASUS Smart Contrast Ratio and 1ms (G2G) response time. It includes a full complement of HDMI, DisplayPort and dual-link DVI-D ports, and the display itself has tilt, swivel, pivot and height adjustments.
[gallery include="" size="medium" link="file" template="file-gallery" columns="2"]
PA249Q
For those wanting immense color and a 16:10 aspect ratio (1920 x 1200) over speed, the ProArt range has also been updated with the new PA249Q. It features a pre-calibrated IPS panel (∆E <5) and six-axis color control to yield the most accurate wide gamut color space reproduction — 99% Adobe RGB, 103% NTSC and 100% sRGB. Other features include the ASUS exclusive QuickFit Virtual Scale, four USB 3.0 ports, and the same full set of tilt, swivel, pivot and height adjustments.
Hit the PR button below to read the full details of both monitors.
In the market for a new monitor, what sort of features are you looking for, or do either of these take your fancy? Let us know in the forums.
Popular Posts
How to upgrade the SSD and reinstall Windows on your ROG Ally or Ally X
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
The 2025 ROG XG Mobile Leads New Era of eGPUs with Thunderbolt 5
The 2025 ROG XG Mobile brings the NVIDIA GeForce RTX 5090 Laptop GPU to the device of your choice with Thunderbolt 5.
The 2025 ROG NUC: Your next-gen mini PC for tomorrow's AAA games
Not all gamers have room for a standard desktop PC. For those who want the power, connectivity, and features of a desktop in a compact setup, we offer the 2025 ROG NUC.
Transcend limits with all the gaming gear ROG announced at CES 2024
Read about all the gaming gear ROG announced at their CES 2024 Transcendance keynote event.
AniMe Matrix Sync brings dazzling coordinated visual effects to your gaming PC
AniMe Matrix Sync lets you apply synchronized effects across all your gear equipped with an AniMe Matrix display.
