ASUS Republic of Gamers Announces Poseidon GTX 980
Nvidia's GTX 900-series 'Maxwell' GPU's gets its first ROG treatment, with the new Poseidon GTX 980!
Featuring the DirectCU H2O, ROG's custom-designed hybrid cooler that works both air cooled or water cooled, allowing you to upgrade from air to water later to increase overclocking performance or just loop it into your existing setup with G1/4" barbs. Perfect for matching with a Maximus VII Formula's CrossChill cooler.
Underneath the DirectCU H2O there's ROG's Digi+ VRM and Super Alloy Power hardware, which can be controlled with GPU Tweak software to overclock.
Spec:
- NVIDIA GeForce GTX 980 GPU
- PCI Express 3.0 interface
- 4GB GDDR5 memory
- 1279 MHz boost clock
- 2048 CUDA cores
- 7010 MHz memory clock (effective)
- 256-bit memory interface
- 1 x Native Dual-link DVI-I output
- 1 x HDMI 2.0 output
- 3 x Native DisplayPort 1.2 output
Click here to see the full picture gallery, and hit the PR button below to read the full details.
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
