Falcon Northwest Tiki: P8Z77-I Mini-ITX And GeForce GTX Titan
It was only yesterday that Nvidia officially announced the fastest single GPU graphics card in the world, the Kepler based GeForce GTX Titan, but its already crept into some pretty impressive looking systems such as the Falcon Northwest Tiki. It can be configured as one of the fastest mini-ITX systems on the planet, with an ASUS P8Z77-I Deluxe motherboard and GeForce GTX Titan packed inside!
The first thing that hits you is its size. That's an Xbox 360 slim its standing next to. Pretty impressive eh? Its only 4 inches wide, 13 inches tall, and sits on a granite plinth to help keep it stable. However, don't let its slender profile deceive you, its jam packed with all the the latest bleeding edge hardware. In addition to the P8Z77-I Delxue and GTX Titan, the Tiki has a watercooled CPU, a pair of 2.5" drives, a single 3.5" drive and a slot loading DVD or Blu-Ray drive that can be loaded from the roof!
The closed loop water cooling system, developed with Asetek, lets the P8Z77-I Deluxe take socket 1155 processors all the way up to an Intel Core-i7 3770K running at 4.6GHz, as in Anandtech's system. The graphics card is unusually mounted in parallel to the motherboard, thanks to a PCI-E port extender, and cools itself via a carefully positioned grilled opening in the side panel. As with all the Falcon Northwest systems, you can customize the paint anyway you want to: providing you can think of it, they can paint it! [gallery include="" size="medium" link="file" template="file-gallery"] Have you made your own powerful P8Z77-I mini-ITX system? What do you think of all the hardware Falcon Northwest have managed to stuff into such a small space: does the Tiki tempt you or do you aim to try and build something competitve? Let us know in the forums.
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
