Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku is back and partnering with ROG for an all-new drop of gamer gear that blends cutting-edge tech with her unmistakable style. This latest ROG x Hatsune Miku delivers world class tech with incredible one-of-a-kind designs that will make any battlestation stand out from the crowd. Hatsune Miku editions of core components like the ROG Strix X870E-H Gaming WiFi7, ROG Ryuo IV 360 ARGB, ROG Astral GeForce RTX 5080 16GB, ROG Thor 1200W Platinum III, as well as the ROG Strix Helios II case and ROG Strix Arion SSD enclosure offer builders the option to create an entirely new build, dedicated to the queen of vocaloids herself.
Killer looks and X3D ready: The ROG STRIX X870E-H Gaming WiFi7 Hatsune Miku Edition
The ROG Strix X870E-H Gaming WiFi7 Hatsune Miku Edition is an instant attention grabber, with a sleek black base coat and Hatsune Miku specific adornments that truly make this vocaloid pop. The large VRM heatsink features Miku and an illuminated ROG “Fearless Eye” logo. Not only is this showcase element done in her signature teal and pink colorway combination, with musical notes, hearts, and equalizer bars gracefully dotting the surface, but the Eye logo also features a Polymo Lighting module that dazzles with multidimensional lighting effects. This stunning motherboard is truly a work of art, and befitting a star like Hatsune Miku.
Prepped and ready for the latest AMD processors, including the incredibly powerful X3D lineup, the ROG Strix X870E-H Gaming WiFi7 Hatsune Miku Edition can drive incredible performance to all of the games in your library. You’ll have access to a powerful suite of performance-tuning tools, including AI Overclocking, AI Cooling II, ASUS AI Advisor, and our latest innovation, AI Cache Boost, which can make it much easier to run an LLM on your machine, even in VRAM-limited scenarios. DDR5 memory support, WiFi 7 wireless connectivity, and ample USB-C ports ensure that this motherboard will last well into the future, and look absolutely stunning while doing it.
Chill vibes only: The ROG RYUO IV 360 ARGB Hatsune Miku Edition
High performance processors demand high performance coolers, but there is no rule that demands they look drab while doing it. The ROG RYUO IV 360 ARGB Hatsune Miku Edition absolutely drips aura, with Hatsune Miku’s signature teal and pink color scheme shining vibrantly across all exposed surfaces, and even within the ARGB fan blades. With a large 6.67 AMOLED display, you can see vital system info or activate some of the custom animations we made for Hatsune Miku via our ASUS InfoHub software. A high flow pump and a large 360mm radiator can easily dissipate heat from even the most high-spec systems, letting you game without worry.
Stunning from 360°: The ROG Astral GeForce RTX 5080 16GB GDDR7 OC Hatsune Miku Edition
From any angle, the ROG Astral GeForce RTX 5080 16GB GDDR7 OC Hatsune Miku Edition is a true stunner. This 3.8 slot, quad-fan GPU demands attention with its bold use of teal and pink across the entire frame. The backplate has a large Hatsune Miku photo, with further colorful adornments. This is the kind of GPU that can draw attention from across the room even before you turn on the RGB LEDs.
Built for those who dare, the ROG Astral GeForce RTX 5080 Hatsune Miku Edition has all the killer features that make an Astral GPU a true flagship. Powered by the latest NVIDIA Blackwell architecture, robust 50-amp MOSFETs ensure incredible power delivery while a patented vapor chamber and milled heatspreader keep temperatures cool. The ROG Astral GeForce RTX 5080 has never looked this good.
Power to perform: The ROG Thor 1200W Platinum III Hatsune Miku Edition
The unsung hero of any gaming PC is its power supply, delivering smooth and stable power no matter what the plug in your home dishes out. The ROG Thor 1200W Platinum III Hatsune Miku Edition is a monster power supply for true enthusiasts, with a 1200W max rating and both 80 PLUS Platinum and Cybenetics Lambda A++ certifications, making it able to easily drive even the most cutting-edge systems.
The ROG Thor 1200W Platinum III Hatsune Miku Edition features a GaN (gallium nitride) MOSFET for up to 30% greater efficiency compared to standard designs, along with patented intelligent voltage stabilizers that deliver power up to 45% steadier than a typical PSU. Intelligent voltage stabilizers allow gamers to activate “GPU-First” voltage monitoring by connecting the dedicated IVS cable directly to your GPU, allowing the PSU to deliver more stable power than with traditional CPU-focused voltage sensing, ensuring smooth gameplay and unwavering performance. Tricked out with Hatsune Miku’s signature teal and pink colorway, this PSU features a magnetic OLED display that shows real time power draw and can be swapped to either side of the unit, making sure the screen is always right-side up in either fan-up or fan-down installations. If you want your PSU to steal the show, look no further.
Command the stage: The ROG Strix Helios II Hatsune Miku Edition
Every PC needs a home, and the ROG Strix Helios II Hatsune Miku Edition is a glorious celebration of everything that makes Hatsune Miku special: bold colors, unapologetic cuteness, and a futuristic style that invites you in. Built from premium anodized aluminum and tempered glass, the case accommodates a huge array of motherboards, graphics cards, and the largest AIO and custom water cooling radiators, making building a breeze. With effortless cable management and ample front USB on the I/O panel, the ROG Strix Helios II Hatsune Miku Edition is sure to make your build instantly stand out from the crowd.
Take the show on the road: The ROG Strix Arion Hatsune Miku Edition
Every idol needs their spotlight, and the ROG Strix Arion Hatsune Miku Edition is your ultimate sidekick for speed and style on the move. Wrapped in vibrant colors and sleek lines inspired by Miku’s futuristic charm, this portable NVMe SSD enclosure delivers blazing-fast performance with USB-C 3.2 Gen 2 connectivity — perfect for transferring your digital setlist at lightning speed. Compact yet durable, the aluminum chassis delivers reliable performance through its excellent heat dissipation, allowing it to withstand life on tour with ease. Screwdriver-free installation makes initial setup and swapping drives effortless. Whether you’re carrying your game library, creative projects, or music collection, the ROG Strix Arion Hatsune Miku Edition keeps your files safe and ready to perform anytime, anywhere.
A visual symphony: The ROG Strix XG27ACMEG-G Hatsune Miku Edition
Take your favorite esports and AAA games by storm with the lightning-fast refresh rate of the ROG Strix XG27ACMEG-G Hatsune Miku Edition. This 1440p 260Hz Fast-IPS display boasts incredible gray-to-gray response times, but the chassis is anything but. Teal, black, and pink offer incredible contrast and instantly draw your attention to the monitor, with subtle ROG and Hatsune Miku accoutrements visible on the base. With seriously competitive specs for any aspiring esports gamer, the ROG Strix XG27ACMEG-G Hatsune Miku Edition could be your ticket to the main stage.
Stage ready style: The ROG T-Shirt I & II, Hatsune Miku Edition
Sometimes the whole world needs to know that you’re Hatsune Miku’s #1 fan. When you need to take your love on the road, we have two custom t-shirts ready to display that adoration loud and proud. The ROG T-Shirt I Hatsune Miku Edition features a large Hatsune Miku outline across the chest, with smaller ROG decals across the arms. And a large “01” on the back cements Hatsune Miku’s place as the world’s first ever vocaloid.
If that isn’t quite your style, the ROG T-Shirt II Hatsune Miku Edition offers a more subtle design on the chest, with a pixel art outline of Miku and ROG on the back. IYKYK.
Party like an idol
The ROG STRIX X870E-H Gaming WiFi7 Hatsune Miku Edition motherboard, ROG RYUO IV 360 ARGB Hatsune Miku Edition AIO cooler, ROG Astral GeForce RTX 5080 16GB Hatsune Miku Edition graphics card, ROG Thor 1200W Platinum III Hatsune Miku Edition PSU, ROG Strix Helios II Hatsune Miku Edition case, ROG Strix Arion Hatsune Miku Edition SSD enclosure, the ROG Strix XG27ACMEG-G Hatsune Miku Edition gaming monitor, and the ROG T-Shirt I and II Hatsune Miku Edition will be available for sale soon. Contact your local ROG representative for more information on pricing and availability.
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
