Maximus VI Extreme Review Roundup
The Maximus VI Extreme is curerntly doing the rounds in reviews and we've zipped up several of the first to hit the net below. If you spot any more please let us know in the forums!
The Asus Maximus VI Extreme is exactly that - Guru3D
Hilbert puts together a huge 21 page review covering everything about the board and new platform, eventually awarding it a Best Hardware Award He has a lot to say, but here's a quote to get you going: Okay let me just tell it like it is, the Maximus Extreme VI is pure sex for the modern slightly geeky man ;) This is quality at its best added with features and easy ways to overclock your processor and memory. Still, this ROG piece of hardware remains to be focused mainly at tweakers. I mean I've seen the competition includes more end-users savvy hip features like dedicated audio solutions, KillerNIC and so on. But man, the Maximus Extreme VI is haaaawt! But yes, the ROG Maximus VI Extreme will be a little more difficult to position as it is pushed so extremely far into the pro-overclockers range with the OC Panel and LN2 functions and so on. Read the full Guru3D review
ASUS Maximus VI Extreme Motherboard Review - Overclockers.com
Overclockers naturally get down into the BIOS, software and chip-level of dissection of the Extreme, so if you want to know the real ins-and-out read this. Overclockers gives it an Approved award. That following has good reason to gravitate toward the Maximus VI Extreme. It includes the most useful, coolest accessory of any board I’ve reviewed. It improves on the past generation both in UEFI additions and software. It overclocks as far as your CPU -and memory- will let you go. Read the full Overclockers.com review here
Asus Maximus VI Extreme Review - bit-tech
The bit folks run the board through their benchmarks and give it an Extreme Ultra award. Because, well, it is. The Maximus VI Extreme's BIOS is your typical ROG affair with more options than you can shake a stick at. However, it's well laid out enough that you can find the basic options such as vcore, RAM voltage, and multiplier and base clock ratios easy enough without trawling through pages of settings. It's the first Z87 motherboard we've seen that allows you to sync the multipliers as well, with other boards often requiring you to set them each individually. It's full of little tweaks like this that just make it easier to work with. Read the full bit-tech review here
ASUS ROG Maximus VI Extreme Motherboard Review - PC Perspective
The PC Per crew put the Extreme through a full breakdown and tests. Here's a teaser: After seeing this board at an ASUS Z87 preview event earlier in the year, I could not wait to get it on the test bench. I was not disappointed to say the least. The board screams performance on initial un-boxing and keeps you busy with its plethora of add-ons. The OC Panel was one among many of the high points for me with this board. The interface is sleek and stylish, matching the looks of the Maximus VI Extreme to a tee. The board itself was designed and laid out almost perfected with a few minor questionable details. Its stock performance was also nothing short of stellar. Read the full PC Perspective review here
ASUS Maximus VI Extreme Preview - OCaholic
Their review should be inbound soon, but in the meantime Ocaholic have put together this full breakdown preview of the board itself. Basically the ASUS Maximus VI Extreme's Layout has been very well thought. Once more practical are the angled SATA connectors as well as the power- and reset-buttons. There is also a debug display which is very useful in case you should have issues with a component in your system or the board itself. Even the placement of the PCI-Express x16 is very well chosen. See the Ocaholic preview here
ASUS ROG Maximus VI Extreme Motherboard Overview Video
[video]http://www.youtube.com/watch?v=r1w2NDB3amc[/video]
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - ASUS GPU Tweak III: The ultimate tool for advanced GPU tuning
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
