Overview: ARES III - Limited Edition, Unlimited Power
The New Performance King: 15% faster performance than GTX Titan Z
This is the ROG ARES III. A limited edition, world’s fastest gaming graphics card, powered by a pair of Radeon™ Hawaii XT R9 290X GPUs. Inside these GPUs pack AMD TrueAudio technology and can take advantage of Mantle-enhanced games.
In raw numbers it has 11.5 teraflops of processing power over 5632 stream processors. It's factory-overclocked to 1030 MHz, and is supported by 8GB of 5GHz (effective) GDDR5 memory. While the GTX Titan-Z is undoubtedly a monster graphics card also, now lets trump it.. convincingly; in the 3DMark Fire Strike Extreme benchmark, this monster card performs 15% faster, runs Battlefield 4 at frame rates 33% greater, and Metro Last Light at 30% faster: all in 4K UHD (3840×2160) glory.
[gallery include="" size="medium" link="file" template="file-gallery" columns="2"]
Engineering Craftsmanship in a Limited-Edition Card
These single-slot cards were meticulously-engineered, and carefully crafted with close attention to detail. They are manufactured in a limited run of individually-numbered units, also making them highly collectible. ROG ARES III includes premium design elements such as its sleek, EK water block that is hand-carved for a precision fit, running at 25% cooler than the reference R9 295X2 (although results will vary according to the performance of your water cooling kit).
[gallery size="medium" link="file" template="file-gallery" columns="2" ids=""]
DIGI+ VRM with Black Metallic Capacitors and 16-Phase Super Alloy Power
ASUS exclusive DIGI+ voltage-regulator module (VRM) technology delivers 16-phase power and digital voltage regulation, while the Japanese-made 10K black-metallic capacitors, Super Alloy Power chokes and hardened MOSFETs can all withstand much greater stress and heat. The result is an ultra-stable graphics card that's forged for loads of headroom for overclocking and tuning.
ROG-Themed GPU Tweak and Live Streaming Utility
Included is the ultimate graphics card-tuning utility, offering incredibly precise control over GPU clock frequency, VRM and even fans. There is also a live streaming utility allowing you to share on-screen action in real-time. You can add scrolling text, pictures, and webcam images to the streaming window easily.
What's in the Case
Yes, the ASUS ROG ARES 3 comes in a metal case. Because you mean business. Here are all the things you need to get started, and more.
- 3 Power cables
- 1 AMD Radeon Gold Reward game coupon
- 2 G1/4 Threaded fitting
- 1 ROG 8GB USB flash drive
- ASUS utilities and driver
- GPU Tweak
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
