Republic of Gamers Announces Maximus VII Impact Mini-ITX Z97 Motherboard
Mini-ITX fans your Z97 upgrade is here! With no less than five daughterboards for all its features, the Maximus VII Impact is the most densely packed SFF board to date.
Its second gen Impact Power II board will overclock Devil's Canyon without limitation, giving you the full potential of your processor purchase; and it's the only mini-ITX motherboard with M.2 X4 PCIE3 support, giving up to 32Gbps of SSD powerrrr. On the flip side of the MPCIE Combo IV is an 802.11ac WiFi adapter pre-installed as well.
SupremeFX audio has been refined to the SupremeFX Impact II with full Sonic software suite, and the LANGuard, Intel Gigabit Ethernet and GameFirst III combination is the same package as its bigger Maximus VII brothers.
On the rear IO the Impact Control II houses the Q-code readout, KeyBot, SoundStage, BIOS Flashback and Clear CMOS buttons, and on the other side sits the fan adapter card that elevates two 4-pin connectors so they are easier to use when building your tiny rig, in addition to the LN2 mode jumper nestled underneath them. Yes - even this ROG board is really built with extreme overclockers in mind too!
Read the full detail in the press release below the gallery.
[gallery include="" size="large" link="file" template="file-gallery" columns="2"]
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
