EK Working On ASUS R9 290X DirectCU II OC Water Block
EK Water Blocks has announced a new full-cover water block for the recently released ASUS R9 290X DirectCU II OC graphics card.
Based on the same full-cover design as most water blocks from EKWB, it will cool the GPU, memory as well as the upgraded VRMs (voltage regulation modules) on the custom PCB. It will feature a new 0.6mm wide micro-channel structure that will further improve heat transfer from copper to liquid, without sacrificing the low hydraulic restriction design, which also means that the new EK-FC R9-290X DCII will work with less powerful pumps as well.
The new EK-FC R9-290X DCII will be available in three different versions and EKWB will also offer an aesthetic backplate as an option purchase. The new EK-FC R9-290X DCII will also support EK-FC Terminal in case you want to pair up to four water blocks.
According to the EK website, the new EK-FC R9-290X DCII should be available early in February next year.
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
