Koolance Releases AMD R9 290X Water Block
While AMD's Radeon R9 290X reference cooler is certainly doing its job in keeping the GPU pretty cool, we've seen a lot of commentators online are still waiting for something more. The ASUS DirectCU II parts are due soon, but if you want an upgrade now and fancy splashing out then Koolance has just launched its Koolance VID-AR290X; a full cover water block designed for the Radeon R9 290X graphics card.
Based on a high-performance micro-fin (0.5mm) design of solid copper with anti-corrosive nickel-plating, the new VID-AR290X full cover water block will certainly keep the GPU and VRM temperatures at much lower levels than the reference cooler. It weighs 0.91kg, features standard G1/4 BSPP threading and can be used in both single and CrossFireX configurations with the appropriate adapters.
No word yet from Koolance on whether it fits the R9 290 (non-X), although both PCBs are identical.
The Koolance R9 290X VID-AR290X water block is currently available from Koolance.com, priced at US $129.99. If you're watercooling your ROG system - drop us some pictures in our forums!
Popular Posts
Where to catch ROG at Gamescom 2025
ROG is doing more than just revealing wild new PC gear at Gamescom 2025 — it’s amping up the party. Check out what we're up to.
The new ROG Dev Accelerator program gives your indie game dev studio the boost it needs
Our new ROG Dev Accelerator program provides a select number of promising indie devs with the hardware they need to build their games.
The ROG Astral GeForce RTX 5090 OC smashes 6 new overclocking records
The ROG Astral GeForce RTX 5090 OC takes what you love about ROG graphics cards and ups the ante to provide you more power than ever before. But don’t take our word for it — look at the records it’s smashing.
The ROG Virtual Assistant gets an AI upgrade with new features
OMNI is getting a big upgrade. Our ROG Virtual Assistant now packs AI-powered features designed to boost your productivity and user experience.
Get ahead of the game with the latest ROG gaming tech from Gamescom 2024
From new X870 motherboards to OLED displays and plenty of mice and keyboards, here’s everything ROG announced at Gamescom 2024.
Buy a GPU and get a free Steam code for Like a Dragon: Infinite Wealth
Purchase select GPUs from ASUS, ROG, or TUF Gaming and dive into an epic adventure with a free Steam code for Like a Dragon: Infinite Wealth!
