How to Prepare ROG Maximus VIII Motherboards for Sub-Zero Cooling
If you own one of the ROG Maximus VIII Series motherboards, and you are looking to attempt sub-zero temperatures, the following guide by Dancop (currently one of the best extreme overclocker) will be a must read. As you may already know, the original paste (TIM - Thermal Integrated Material) between the "brain" of the CPU (die) and the copper cover (IHS - Integrated Heat Spreader) which helps draw heat from the CPU are additional mediums in the heat transfer process for safeguard. Although the TIM and IHS are necessary for safe handling and installation, they do affect efficiency when you are looking to achieve the ultimate cooling and the infamous ice-ball crack may occur in the paste when dealing with sub-zero cooling.
To remedy that problem, extreme overclockers found ingenious (and gutsy) ways to apply a higher-quality thermal paste.
Using the Delid Die Mate, an advanced delidding CPU tool by der8auer (another world-class overclocker), Dancop is going further and revealing to us the best techniques to apply the thermal paste between the IHS and the die, BIOS settings recommendations, and tips while benching with LN2. If you are looking for a real challenge, the following guide is going to be a lot of fun, but please remember - this will be at your own risk.
How to Prepare ROG Maximus VIII for Sub-Zero Cooling
Here, I want to share some of my experiences.
Many of us know the Ice-Ball crack. Therefore, I’ve tested a hell lot of pastes, whereas FRESH Grizzly turned out to be the best!
Read it here (in the meanwhile I’ve tested around 15 more pastes!):
Test of Thermal pastes for the DIE on Skylake - Or the ICE-BALL Challenge
After confirming that grizzly is the best, I’ve tried some things and found one preparation/setting combo, that works on more 60 chips on cold! None of these chips had any CB nor a crack within the first hour of benching.
This is what I want to shae, in three parts:
1. Preparation
2. BIOS Settings
3. Handling
Boards I used:
ROG Maximus VIII Extreme, Hero, Gene and Impact (You’ll see the differences in the BIOS section)
Let’s begin!
1. Preparation
Everybody knows, a delidded CPU is obviously a must for Skylake-LN2 overclocking. Changing the original Intel TIM to the TIM you want to use – again, Grizzly seems to be the best in terms of cracking and temperature behavior! This is just my personal experience.
When you look at the original Intel TIM after you delidded the chip, you’ll recognize a very thin layer of TIM. This is what you have to change now!
Furthermore - after delidding, DO NOT ERASE THE GLUE!!!
Here you can see one of my chips cleaned after the last session (for me it is A MUST TO CLEAN IT EACH SESSION!) :
After the cleaning part, you should use at least as much TIM as I’ve used here:
Now you have to apply the TIM on the die, but now you’ll see an example how you shouldn’t do it – THIS CAUSES CRACKS! :Now you have to apply the TIM on the die, but now you’ll see an example how you shouldn’t do it – THIS CAUSES CRACKS! :
The following photo shows HOW TO APPLY THE TIM! Try to “enlarge” the die to each direction about 2-3mm. The TIM besides the die should almost have the same height like the die itself:
Now put the chip into the socket:
Use the little PCB frame from ASUS to fix the chip in the socket:
[gallery include="" size="medium" link="file" template="file-gallery" columns="2"]
When you dissemble everything, the core should look like this for 4-core:
This is the most important part, as the bios settings might differ a bit from chip to chip, although the BIOS settings I’ll show you, work for 98% of the chips. Except the very golden ones, they don’t like pll termination – more now…
2. BIOS Settings
The most important thing here are not the voltages – it is the PCIe setting in the advanced menu! DO NOT CHANGE ANYTHING HERE!!!! Leave everything on auto! Even with a bclk of 164, I can run PCIe 3.0 with the settings on auto. If you change them to 1.1, you should probably get a freeze at around -170 degrees.
Let’s move on with the voltages. One thing before the important settings – If I don’t see a certain setting, it is not touched, so still on AUTO.
Always disable SVID support.
Furthermore, set everything to the max in DIGI+ control – EXCEPT THE FREQUENCIES – I always leave them on auto.
In Tweakers Paradise you find some more voltages. But I only adjust these three voltages:
DMI: 1.5V
Core PLL: 2.4V
PLL-Bandwidth: Level 6
I’ve tried several Bandwidths and 6 turned out to be the most useful.
Core PLL obviously helps a lot for the cold bug. But you can try to lower it at fullpot in the OS! Then boot with this setting afterwards…but be careful – sometimes the core pll needs to be adjusted after 2 hours, that’s why I always use 2.4V.
Now DMI on M8E for 2d (option1 – in handling part needed) – just keep it at 1.5V and use the GPU in the last slot.
DMI on M8I for 2D/3D and M8E 3D (option 2) – boot with 1.5V and pour your pot down to -160 degrees. Now adjust 1.85V- 1.9V. You need to figure out, how strong the combination between CPU and board is.
My gem chip for example needs 1.88V on extreme and 1.9V on impact.
WHILE ADJUSTING….POOOOOUUUUURRRRRR! up to fullpot. You can get a black-screen very shortly, but screen comes back for 99%!
Besides the tweakers paradise, we have the normal voltages.
CPU: What U need
DRAM: What U need
Pll Termination: 1.65V
Standby: 1.35V /1.65V on hero, cause there's no pll termination, they are linked.
You miss VCCIO and VCSSA? See the first sentence in this part. Sometimes for heavy 3D benchmarks and very high clocked GPUs, a VCCiO around 1,45V helps stabilizing the GPU.
Regarding CBB, you can test the original CBB of the cpu at stock settings. Leave all at default and try the lowest CBB. Cause if you adjust 1.65V pll termination, your CBB might be much worse than before. If you normal CBB is around 140 and you try to boot with 1.65V pll termination and your CBB changed to -100, then try to boot with 1.5V pll termination and raise it in the OS afterwards.
3. Handling
Here are some important things for the handling, while fullpot benching.
There’s a reset CBB on those chips – not all have it, but let’s say 80% of them. That means, when you are at fullpot, and press reset, you’ll see 25 postcode. Same with crashes for sure.
So, if you have a BSOD, then torch the pot up to -173 and you can reset it very easy.
Now let’s talk about the ultimate handling.
When you have prepared the CPU properly and found your bios settings, then you can boot at around minus 80. I always boot with the above settings and 5G on core and cache and 1.5V on the CPU. Once you are in the OS, you can go fullpot. Then set Vcore, pll termination multipliers and have fun! The most important thing for option 2 has already been explained. Here again – on Impact, ALWAYS OPTION 2 IS A MUST!
Once you hit fullpot, you can play until it crashes for sure – try to keep the temperature ALWAYS BELOW -135. If you’ve reached -100 once, some CPU love to crack then! So…NEVER EVER GO HIGHER THAN -135.
Don’t try to boot with 1.8V DMI – you’ll always get 25 postcode.
Don’t try to boot with 1.75 pll termination – you’ll sometimes loose you SATA
Last but not least –
If you have any questions, feel free to ask!
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - ASUS GPU Tweak III: The ultimate tool for advanced GPU tuning
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
