Hands On: USB Spitfire Audio Dongle For Vulcan Pro & Orion Pro
Exclusively bundled with the new Vulcan Pro and upcoming Orion Pro headset is the Spitfire USB audio dongle. While the headsets themselves can plug straight into 3.5mm audio jacks on your PC or notebook, the USB audio dongle adds an interim audio processor with three buttons to enable its headphone amplifier, 7.1 virtualized surround and 'FPS Mode' tweaked audio.  The Spitfire has two 3.5mm audio sockets the headset plugs into. This means you don't have to use it all the time, even if you still want to use your Vulcan's or Orion's. The other advantage is that these are standard sockets, so you can plug the Spirfire into any headset that uses 3.5mm stereo plugs!
 The Spitfire has two 3.5mm audio sockets the headset plugs into. This means you don't have to use it all the time, even if you still want to use your Vulcan's or Orion's. The other advantage is that these are standard sockets, so you can plug the Spirfire into any headset that uses 3.5mm stereo plugs!  The fact it's USB means you bypass the internal audio on your motherboard or notebook. This can be a real boost for those with basic audio, or if you're gaming on a pre-built LAN system, in an internet cafe or a tournament PC, for example, as the Spitfire is purely plug-in-and-play; requiring no extra driver install.
  The headphone amp, 7.1 virtual surround and 'FPS Mode' can be triggers by simply pressing the separate buttons, with a red backlight glowing as indication to which is turned on.
 The headphone amp, 7.1 virtual surround and 'FPS Mode' can be triggers by simply pressing the separate buttons, with a red backlight glowing as indication to which is turned on.  The new Vulcan Pro and upcoming Orion Pro both come bundled with the Spitfire.
Popular Posts
 - How to adjust your laptop's P-Cores and E-Cores for better performance and battery life
 - Prepare for Tandem OLED splendor with these new ROG gaming monitors
 - How to Cleanly Uninstall and Reinstall Armoury Crate
 - 32-inch glossy WOLED panels debut in the ROG Strix OLED XG32UCWMG and XG32UCWG gaming monitors
 - ASUS GPU Tweak III: The ultimate tool for advanced GPU tuning
Hands-on: The ROG Raikiri Pro took my couch gaming to the next level
I've been a diehard PC gamer all my life, but I often play on the couch. The ROG Raikiri Pro has improved my living room PC gaming immeasurably thanks to a few useful features and loads of customizability.
Hands-on: The ROG Azoth became the canvas for the keyboard of my dreams
Ever since I bought my first mechanical keyboard, I’ve been on a mission to mod and upgrade, mod and upgrade. But I think the ROG Azoth may actually be my endgame.
The Zephyrus M16 blends outstanding HDR gaming performance with undeniable luxury
The new ROG Zephyrus M16, with its Nebula HDR display, is like bringing a high-end home theater gaming setup with you wherever you go.
Radeon graphics and a stellar new display reinvigorate 2022 ROG Zephyrus G14
For a long time, I had to choose between underpowered ultraportable laptop and large laptops capable of gaming. But the ROG Zephyrus G14 puts admirable gaming chops into an ultra portable machine that travels anywhere.
Ready to rumble out of the box: Hands-on with the ROG Strix SCAR 15
Living on the move or in a smaller space isn't a roadblock to high-end gaming. The ROG Strix SCAR makes portable powerful.
The ROG Zephyrus S17 is an outstanding mixture of power and portability
The S17 has it all: top-tier hardware in a slim package with all the bells and whistles.
