Maximus V Formula Hybrid Thermal Solution Compatibility List For Watercooling
Do you want to do something like this?:
The ROG team has put together a page to list compatible watercooling products for the Hybrid Thermal solution.
In addition to the list, look for these logos on watercooling kits and part makers websites:
Hybrid Thermal Solution Compatible means CPU waterblock fits and works with Hybrid Thermal solution, while Hybrid Thermal Solution Qualified means the whole watercooling kit can fit the Hybrid Thermal solution into the loop.
For example, EK has both kits and CPU blocks that are both compatible and qualified.
If you're putting together your own watercooled Maximus V Formula, please share your pics in the ROG modding forum!
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
