ASUS Republic of Gamers Announces Maximus VIII Hero Alpha
ROG Maximus VIII Hero Alpha is built on the solid foundations set in the ROG Maximus VIII Hero, and the most popular motherboard in the ROG Maximus VIII series is back with significant upgrades! What made the Hero highly desirable was the fact that it simply looked badass, or perhaps it's also the ability to fully exploit the new Z170 platform using an Intel LGA1151 Core i7/i5/i3 processor and Dual DDR4 3733 (OC) memory with Intel Extreme Memory Profile (XMP). This is all made possible by implementing 5-Way Optimization auto-tuning technology for easy performance boosts, power-savings, ultra-quiet operation or even custom audio/networking settings for games, Pro Clock technology in tandem with TurboV Processing Unit (TPU) turbo-charge the base-clock (BCLK) frequency on your 6th Gen. Intel processor, and Second-generation ASUS T-Topology for superior DDR4 memory overclocking, ensuring time-aligned signal transfer for stability and compatibility (which is not an easy task these days as we are hitting such high speeds for memory). The new Hero Alpha can push memory even further by supporting up to DDR4 3800+ memory.
As you can see, the new Maximus VIII Hero Alpha still looks badass, and even more so now that there are Aura RGB Strip headers. ROG Maximus VIII Hero Alpha is the first ever to implement these patented 4-pin Aura RGB-Strip headers (extension cables included) so you can light up your rig or even the room! The Aura lighting-control utility software allows you to not only configure the RGB LED lighting on the motherboard but also the attached RGB strips, there are six lighting modes: static, strobe, breathing, color-cycle, music effects and it can even change colors to indicate CPU temperature.
[gallery size="medium" link="file" template="file-gallery" columns="2" ids=""]
Apart from the the aesthetics and improved memory speed, there is superior connectivity. There are now dual NVM Express (NVMe) U.2 sockets (no Hyper Kit required), in addition to the existing M.2 socket (supports both SATA & PCIE SSDs) so you can obtain speeds of up to 32Gbit/s and insane 3-way RAID setups are possbile! There are four SATA 6Gb/s ports, more USB ports, a Thunderbolt 3 capable Type-C port on back panel, 2x2 (2T2R) 802.11ac Wi-Fi with Multi-User MIMO (MU-MIMO) and Bluetooth V4.1.
All the other already-outstanding features you found on the Hero are also on the Alpha, such as the new SupremeFX 2015 audio solution. You can now also test out GameFirst IV (Beta) technology by downloading it here for the best gaming performance on the network.
Hit the PR button below for the specs and more info!
Popular Posts
Take your ROG allegiance to the next level with an OMNI action figure
The Republic of Gamers’ famed mascot, OMNI, comes to life through two new collectible action figures.
With the ROG NUC, your only limit is your own creativity
The small size, potent performance, and versatile connectivity of the ROG NUC makes it a perfect fit for a wide range of scenarios.
Graphics cards, monitors, motherboards, and more: everything ROG announced at Gamescom 2025
ROG is a making a splash at Gamescom 2025 with a new Matrix graphics card, Hatsune Miku gear, and much more.
Hatsune Miku and ROG deliver a killer lineup of gaming hardware
Hatsune Miku and ROG are teaming up to give you gear for the ultimate vocaloid-themed gaming PC battlestation.
Brighten up your battlestation with new white ROG peripherals
Whether you want frosty peripherals to stand out amongst your hardware or blend in with your Moonlight White setup, we have you covered.
All the new gaming gear revealed from the ROG Lab at CES 2025
ROG is going harder than ever in 2025. Here's everything we announced at the Consumer Electronics Show this year.
